Scroll down to the section:
Restore your device to factory settings
Note:
Step 1 has two links:
one that shows you how to do a factory reset using your computer and iTunes, with your iPad attached to the computer. The other link show you how to do a factory reset without your iPad attached to a computer and using iTunes.
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
On the back of your router, locate the Restore Factory Settings or Reset button.
Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
Release the Restore Factory Settings or Reset button and wait for your router to reboot.
After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
Note: The Power light on newer router models lights solid white.
The factory default settings are restored.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
If your Lenovo desktop is pre-installed with Windows operational system, press one-key reset key when your laptop is power off. Or press Shift + B to come back to factory setting instantly when Lenovo desktop is open.
Or press F2 when your Lenovo desktop is powering on. Few seconds later, a dialog pops up with several options, one-key reset and reset factory setting. Follow the operation wizard to reset factory setting is OK.
Check sum failure is an error on the configuration of the computer board. You have to reset the computer board to factory setting to get rid of this error (if check sum failure appears every now and then on the display). Make sure that you have the list of your cooking parameters before you reset the board to factory setting. Any settings made prior to a factory reset will be lost. Details on how to reset the board to factory setting can be downloaded at pitco website on www.middleby.com.
In order to reset your computer to factory setting you have to have the system restore disk and put it in your cd drive and reboot your computer with it inside... after pc boots up, a screen should popup click on restore to factory settings... if you dont have a disk reply back and i can give you a link for download..
If you want to completely reset it back to the original windows settings you must re-format your computer. This won't put the original programs back on it that you had before, but it will give your computer a COMPLETE reset. Meaning also that if you want to keep some data you must put it on some external drive because your hard drive will be completely overwritten.
If you want to get it back to just the factory settings, you could try to contact their customer services if they don't anything on their site to help you, although I would not recommend it. Factory settings aren't the best because they usually put stuff on your computer that you don't really want. Re-formatting is the best thing to do.
