All windows went at the same time even the lock. Checked fuses they are ok now what?
SOURCE: BMW 740IL Wiper Issue
try checking for a short to power on ur 12 volt comming into motor also check for a good ground at the plug for ur wiper motor
SOURCE: HAVE A 03 GMC SIERRA
I had the same problem in my wife's 2003 Yukon Denali. The power seats and passengers side window wouldn't work. Turned out to be a blown Buss Type fuse in the Underhood Fuse Block. It is the one marked MBEC 1 50amp. Hard to tell if the are blown so look very carefully. Should look like a hoop with two shiny solderlooking bubbles on either side. On my blown fuse, it caught my attention because it looked like the solder was missing and I had to look very closely to see the bottom of the "hoop" was open. They are very hard to remove and must be pulled straight up.
This type of fuse looks like a red square with a clear plastic top showing the fuse link under the plastic. On my vehicle it is on the top row second one from the left.
SOURCE: power windows in my ford explorer do not work at
remove or peel back the black boot in the door jam. you probably have a broken wire.
SOURCE: Power windows dont work
If all windows stopped workin at once it's a relay ... You can usually find them under your steering wheel ... You more than likely have to remove the panel under the steering wheel and you'll see them... I forgot which one it was but call a BMW dealership ... And let them know what relay you need...
Car not starting or turning over indicates towards multiple possibilities.
It can be issue with battery or weak battery. But if battery checks out ok, then
it can be starter issue or faulty alternator or problem with low fuel pressure
or no spark at spark plugs due to dirty spark plugs or faulty
ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This will help.
Thanks.
