My GE washing machine doesn't always get items fully wrung out after the spin cycle. There is still a bit of water at the bottom of the machine. I ran a cycle with the washer empty and all the water appeared to have drained out.
SOURCE: zanussi washing machine
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
SOURCE: the drain/spin cycle always adds water
It's normal if it just adds a little bit of water. It does this so your drain pump impeller doesn't run dry which could damage it. If it's filling right up, there could be a malfunction with the control board, the pressure switch or the inlet valve .
You could try shutting off the water supply at the taps before you start the drain/spin cycle.
SOURCE: My washer wouldn't drain or spin. It just humms
OK ! TRY this , located the DRAIN MOTOR PUMP , usually where the drain hose is connected , remove it , check for any debri or lint clogging the PUMP , replace and try again, hope it helps , AJ
SOURCE: Leaking washing machine
It is so common that the drain leaks in many ways andis the most problematic fault in a washing machine. In all occasions it isimportant that your observation is most important and so is vital to theidentification /rectification and solution. If you have noticed that water hasleaked then as the drain hose pump/valve and fittings are located on theunderside of the machine it is important that you look for possible leaks here.In some cases the drain hose would be clogged at the drain end to outlet of thehouse and so there will be back flushing resulting in overflow to the outside.Also the drain pump/valve can be clogged or the drain hose clamps can be looseon the grip which can all cause the leak to occur. Removing and cleaning thedrain pump/valve, tightening of the hose is also very important. Also water canleak if there are gaps on the front door gaskets and must be checked but thiswill happen only during the cycle and not on the drain cycle end.Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html Check for tips on the link below to identify parts andremoval:http://www.espares.co.uk/advice/washing-machines/a/7
