Ive got a baumatic Titan5 and the fridge temperature is too warm. I have tried making it cooler, but the temp goes right back up to 19 degrees!
As you know this is very large fridge and try to find service manual for help and solve problem with using deduction method of step by step trouble shooting and eliminate possibilities
This might be compressor problem or evaporator problem or main controller problem or sensors or etc.
Baumatic TITAN 5 Stainless steel 4 door 607 Litre Frost Free Fridge/Freezer
Technical Details :
* Total gross/net capacity: 607/557 litres
* Gross capacity fridge/freezer: 428/179 litres
* Net capacity fridge/freezer: 397/160 litres
* Energy efficiency class:
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
SOURCE: Samsung RS21w USA style frige freezer panel problem
If the fridge has been making more noise than usual, like the sound of a plastic fan grating against something then the fan has probably seized up with ice. This will cause the fridge temperature to rise. It is located at the back of the fridge behind a plastic panel at the bottom where the water cooler pipe and bottle are. You need to partially remove this panel just enough to be able to aim a hairdryer down the back of it to defrost the fan.
SOURCE: K-Mart Homemaker brand, 40 bottle wine cooler fridge
Are you sure you want frozen champagne? Or do you mean 7 degree C (not minus 7).
SOURCE: Fridge Freezer will not maintain fridge temp, but freezer fine
My miele fridge freezer has just come up with a fault code F4 where the temp is... what does this mean and how can we fix it???
