That is a trouble code from the dishwasher indicating the computer ran into an unexpected problem.
This link has a pretty technical discussion of your exact problem: http://www.ukwhitegoods.co.uk/forumsphpbb3/dishwasher-forum/hotpoint-fdw60-error-codes-fast-eco-t23513.html
Your problem is a "drain time out error", which means the dishwasher waited for the water to pump out and it never happened (sounds right!).
There are a few things you can check, but unless you're very handy you will probably need a professional:
1) Is the drain line from the dishwasher to the drain plugged by anything? It could be clogged with debris that's been washed off your dishes over the years.
2) Is the drain inside your dishwasher plugged? You'll have to scoop out the water inside to see.
If neither of those, it sounds like either the onboard computer has failed and needs to be replaced, or the pump is plugged or wrecked. In either case, paying for the repairman's time will probably be more expensive than the parts themselves.
SOURCE: Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
SOURCE: blocked hotpoint dwf 33
There is a drain hose for your dishwasher and it often gets clogged. remove and clean it , reinstall and problem solved. If this doesnt fixya then might have to throw parts at it. Not sure though without cleaning the hose first. Good luck
SOURCE: Hotpoint BF162............. Water left, not draining
Open the bottom panel of the washer and see if it is full of water, if it is drain it away and clean all of the filters inside the washer and reset.
SOURCE: eco and fast wash lights flashing together and
this does mean draining cycle has timed out due to either blockage or faulty pump...
