For future reference disconnect the positive lead if you are not going to use it for a long period of time.
Using a multi-meter, set the dial to read Vdc.
Take a reading of the battery voltage and note it. If it is low you'll need to charge it to it's full capacity in order to perform a load test.
Take another voltage reading to verify that it is fully charged.
Using a load tester, put the battery under load for 30 seconds and release the load switch. Read the meter on the load tester to see if the battery is still good or if it needs to be replaced.
I use a KAL-Equip 4260 [100 amp] load tester- it's capable of checking the charging system as well.
If the alternator is bad, you'll need to replace it with a new or rebuilt- or if you are mechanically skilled in this area of an auto's electrical system, you can purchase a rebuilding kit at any auto parts store.
If you're budget cannot afford buying a load tester and charger- bring the battery and the alternator to your local auto parts store and they'll test them for you- free of charge (at least where I live)
Cranking and not even trying to fire is usually a fuel pump failure. First be sure it is quiet at the vehicle area. Battery is fully charged. Set in vehicle, radio & a/c-heater off. Turn key to on/run position for 3-5 seconds there should be a faint sound of electric motor (fuel pump) running. Turn key off for 10 seconds & try again. No sound of it running? Then next simple check is to have a person crank the engine while you hit the bottom of the fuel tank in center area with a hammer. Repeatedly hit it with solid hits (not too hard, you do not want to damage the tank) while cranking. If the engine starts the cause is the fuel pump motor failure. This requires to remove the fuel from the tank & lower the tank to replace the fuel pump. You must get at the level below 1/4 tank to safely handle the tank.
If your engine did not start & you do hear a fuel pump 3-5 second prime then you could have a ignition failure. The most common is the coil wire corrosion in the boot and the tower of the coil. Check this at the distributor also. Also check all spark plug wires for corrosion. Best to replace these parts if corroded. If you do not replace them next best is to wire brush and seal with wheel bearing grease or ignition dielectric grease. Use grease on new parts you are replacing also. Sometimes the grease you add causes the boot to seal & air in the boot pushes the boot back off a little. The boot needs to be released of the air in it. Slip a very small screwdriver under the boot while pushing it on then there is a way for the air to escape.
Chris
ASE Master certified sense 1979
SOURCE: gmc safari van cranks over, but will not fire up
I had the same problem with my 2000 GMC Safari two years ago....drove me CRAZY!
Sometimes it would start right up...other times it just would crank and not start.
It turned out to be a cracked coil....I found it by using a spray bottle with water in it, and "misting" the engine, at night....with the engine running. (On a night when it DID start!)
It took a while, but finally the hairline crack let in some water and the electrical short showed by a spark coming out of the coil.
I replaced the coil with a new one, and it has never "not started" since.
Evidently the coil cover gets brittle and develops small, hairline cracks due to heat from the engine.
Oh...by the way....I tested the coil it showed that it was fine!....but it took the "misting" at night...in the dark...to find the spark "leaking" out.
SOURCE: 1994 GMC Jimmy hard to start and runs rough when first started
i think if you checked the sparking plugs and map sensors then check your distributer its maybe not delivering the current nedded to perform the spark to some of the cylinders
SOURCE: 96 gmc sierra hard to crank after 12-14 hours
that has a votec engine in it the fuel pressure is droping at knight and it takes 60 psi before the injectors will fire most likely cause fuel pump ,leaking injector ,or a feul pressure regulator
SOURCE: turn over but wont crank up
check your E.C.M. fuse, then you could have a bad E.C.M. or coil packs on the vehicle
SOURCE: 1998 GMC Jimmy won't start.
could be bad ignition, leak in the fuel line, master coil that powers sparkplugs, sparkplugs, sparkplug wiring, electrical fault there could be a number of things but this is were i would start....a mechanic will help more! i hope this helps
