Music Logo
A
Alan McConville Posted on Dec 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I connect only one speaker to a yamaha emx 312 sc power mixer?
How can I connect only one PR 15 Peavey speaker to a Yamaha emx 312 sc power mixer? I know the mixer is stereo and I have 2 pr 15 speakers, but if I needed to save space, could the mixer be used to power a single mono speaker?
David Payne
Level 3:
Top Expert:
  • Yamaha Master 14,162 Answers
  • Posted on Aug 01, 2015
David Payne
Yamaha Master
Level 3:
Top Expert:
Answers
14162
Questions
0
Helped
2998379
Points
455836
Set to mono and turn your balance to one side. problem solved. very old trick. done it many times.
thompsonfix
Level 1:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Contributor 37 Answers
  • Posted on Dec 06, 2013
thompsonfix
Contributor
Level 1:
Night Owl:
Answers
37
Questions
0
Helped
10765
Points
98
First it is certain that you would not want to plug both outputs of the stereo power amp into one speaker combining both channels into the same speaker. (see image from manual below - also link to manual)
Next I would be very concerned about only using the one side of the main amp out as it could cause an unbalanced load, or you could be driving the load into dead air connection and any of these conditions are destined to cause premature failure of the power amp.
Taking a quick scan of the manual for this unit, it appears what is pretty common to most powered mixers, hook up two matched speakers/loads to each chanel of the output.
Your best bet is to shed those monster cabs, there really is no need for them especially with this sized powered mixer, and get yourself a nice pair of full range cabs like EV1202;s, EV SX300's, or some nice 2 or 3 way 15" JBL's/
Just my opinon.
Link to Yamaha EMX 312 Owner's Manual:
Yamaha EMX Series Owners Manual
can I connect only one speaker to a yamaha emx 312 - 6d808d37-09a3-43cc-9359-fa69a96128e5.jpg
1 Related Answer
Anonymous
  • 298 Answers
  • Posted on Feb 10, 2011
SOURCE: The speaker connected to my
Assuming that you have checked the speaker leads for broken connections and that you know the speakers themselves work okay (test with a different amp) and that you can hear sound on the headphone socket
  1. Check that you actually have the power amp switch in the right position for the outputs (monitor jacks or main neutrik/speakon sockets) that you are using (see page 25 of the manual)
  2. That your speakers are connected to the speaker outlets on the rear panel and not the 'main outputs' on the front panel, which are for use with a separate power amplifier
  3. Check the mute button is not in
  4. You have turned both the master volume controls up.
If none of the above solves the problem it is likely that the overload protection fuses on the amplifier output stage have blown and need replacing - take to a repairer
You can find the user's manual here
http://www2.yamaha.co.jp/manual/pdf/pa/english/mixers/emx512sc_en_om_d0.pdf
1helpful
Noise from a Yamaha EMX 2000 Powered mixer
Sounds like it might not be cleaned enough. They may have done the pots but the internal circuit boards may not have been done enough.
Yamaha emx 88s
amplifier module faulty, it may even damage your speakers if it had dc on the speaker terminals. have a qualified technician to check and confirm all components.
Muffled Sound From Speakers.
Please illuminate me explaining the word "Muffled" means and i will be glad to help you out...
1helpful
What was the glowing inside my peavy pr 15 pa cabinet when I turned up my treble on my pa amp by accident? There was no damage I was just curieous as to what that glowing was
There is a speaker protection circuit that uses a lamp that will light IF you are driving the spoeakler TOO HARD !!! You can search for "Peavey speaker protection" circuiot online.
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
1helpful
Aux1 and 2 are not working...what is the fix on the emx5016cf yamaha board
You are NOT trying to drive speakers from the aux outputs are you? These are LINE outputs that should be using TRS balanced lines to either powered speakers or amplifiers. Often these are used for monitors. The monitoors MUST be powered versions or use external amplifier if the speakers are passive..
The speaker connected to my Yamaha EMX 312 SC is not bringing out any sound when we use the microphones but the displays on the power mix shows there is activity.
Wound the yamaha MG102c be good for a small duo or solo
Use either an amp OR powered speakers. Make sure you use balanced lines to the external amp or powered speakers and power those from the SAME receptacle source as this mixer and any pwered devices connected to it for safety of the system.
Top Yamaha Music Experts
Paul Bade
Are you a Yamaha Music Expert? Answer questions, earn points and help others
