When i turn on the ignition, the teh dashboard lights come on, but theres not even a sound from the starter motor. battery is charged sufficiently. havent driven the car in 2 months.
What makes you think the battery is charged sufficiently? My guess is that your battery doesn't have enough power to crank the engine (just because all the lights come on doesn't mean the battery is good enough to crank the engine). Try jumpstarting the car, or charging the battery. If your car starts, then your battery is getting old, it's time to replace it.
SOURCE: Car won't turnover...only a clicking sound when turning ignition
A small battery charger may take 24 hours to charge your battery. If you are sure the battery is fully charged then you may want to clean your battery connections.
SOURCE: Battery was low and turned
hello there
i would like to help you,would tell me how did you check there is no fuel?
[email protected]
proporsche
SOURCE: I have a 1977 Porsche
hello there
Most likely you need to replace your electrical portion of the ignition switch.It is a common problem.
here is the part number
111 905 865 L
[email protected]
proporsche
charge or replace the battery.
