How do i add music from my computer to my phone wehen i plug in the cord to the computer to phone it just charges a lot of the help i have seen says to check mass storage i dont have such an option ?
Hello William,
To transfer files using USB devices
SOURCE: LG PHONE PICTURES INTO COMPUTER
you need to go to your menu bar
go over to settings and tools
go down to memory click on phone memory
down to my pictures
click options
move
mark all
and click done
and they should all move to your memory card.
hope it helps!!
((same for Videos))
SOURCE: i have the lg lotus and i want to upload videos
when you plug in connect the phone via the usb cord a window should pop up asking if you want to view the folder. select this option. when you click it, you should see four folders. dcim, music, email, bluetooth. click on dcim. your videos should be stored in this folder. just click and drag them into whichever folder on your pc you want them in. or, when you connect your phone it will give you four options. transfer music, mass storage, phone as modem, pict bridge. select transfer music. this should make the previously mentioned window pop up and you can follow my instructions from there. or, if you have you videos stored in the 'in phone' part of your phones memory you need to move them to your 'memory card' memory. just select 'options', then 'move'.
SOURCE: How do I transfer computer images and music to my LG Voyager?
If you already have the drivers installed and it still doesn't show up as removable storage in My Computer, you may have to go to Settings & Tools -> Tools -> USB Mass Storage (on the phone, while it's connected)
SOURCE: how to upload pictures from phone memory card???
Plug the usb cable ino tthe computer you want the images in adn your phone (of course)...go to tools - USB Mode - Mass Storage and connect...
in the computer on the removeable memory or disc in teh DCIM folder is another foler mine is 100LGDCF and in there are your images...you can delete or copy...to the computer...if
SOURCE: how do we add music to the LG xenon
[Extra Hardwares Needed]
1. MicroSD card
2. "Micro-B" USB data cable
[Procedure - either PC or Mac]
1. Disconnect USB cable (if you connected already)
2. In Xenon phone
Settings -> More -> Connection -> USB Connection
-> (select) Mass Storage
Note: If you don't do this, you will get an error message
"Unable to use liscense. TRy again after formatting memory card."
3. Insert MicroSD card into Xenon phone slot
4. Connect Xenon phone to PC (or Mac) using USB cable
5. If MicroSD is not accessible as a disk drive, then
(1) remove the MicroSD from Xenon
(2) format the MicroSD from PC
(3) retry step# 3 & 4
6. You can drag & drop your folders and/or files (.mp3 or .m4a only)
into the MicroSD card
7. Disconnect Xenon phone from PC then go to "AT&T Music" -> "Music Player"
Note: All features work except for "Playlists"
8. If you want "Playlists", you need to use Windows Media Player and sync.
iTunes doesn't work since it doesn't allow other devices than iPod.
This means that you cannot use Mac to create/sync the playlist.
