When I print a card on my HP Photosmart 8250 printer the copy is a fourth of an inch too low on the page so it cuts off the bottom of the copy. How do I change the calibration?
Fig 1:Remove the spring cut 3-4 curls & fix it back, do
the same way other side also to give more tension to tray1, technic behind this alteration when solenoid leaver
released, tray 1 add more force to
rotate paper pick up roller assmly quickly. Add a little bit of grease to the
surface see Fig2. Remove solenoid clean it fix it back Fig3
. Clean & grind
surface of registration rollers to hold paper properly. Clean paper registration sensor.
The page margins appear in your document as dotted lines.
You can use these dotted lines to correct your margins so that your student's assignments are not cut off and there is no large margin as you have mentioned in your question.
You can view page margins in either Print Layout or Web Layout view only, and they do not appear on the printed page.
Hope this helps
