Ink system failure
Ink system failure is a faulty printhead issue - call hp and they will have you do a cleaning. Rarely solves the issue and they will end up sending you a replacement printhead.
There support # 800-474-6836
This is for 2 ink systems like #74 and #75 ink. First try opening the printer and removing the ink cartridges. See if the error goes away. If it does, one of the ink cartridges are bad. If error goes away, put both in the printer and remove only one at a time. Also, the issue could be with a piece of paper or other small object inside the printer.
