if you can look at the underside of the board with the resistor on it, take a magnifying glass and look around the pins poking through from the components. It may be that the heat as unsoldered a component (be it resistor, capacitor or otherwise). Look for gaps in the solder around each pin, and if there are any holes around the pins, try filling them in with a little solder.
After acquiring a fried KLH ASW10-120, I write to the tech folks at KLH and they sent me the upper and lower board schematics. I asked if I could publish them online, and explicitly asked if I could share them on FixYa.com, and they gave me permission to do just that.
I would fit the same type, unless the schematic shows a change, which clearly it doesn't. However I would be surprised if R42 burnt up alone! Look at the schematic, is R42 linked to any other transistor or part? If so check them if you can.
By the way is R42 a fuseable resistor, for example is the symbol on the schematic or on PC board different to most other resistors?
470.000 ohms not 470 ohms 470k ohms at 5% tol. either the main p.s. diodes are shorted or the output and driver transtors are shorted causeing the fuse to blow....
First of all a resistor color coding of Yel-Vio-Yel is 470Kohms not 470ohms. You are probably reading some stray voltage in the circuit. Yes, both NEG terminals of the speakers are common. Usually a receiver that blows the main fuse has a power suplpy problem. Check the recifier diodes for shorts. Other than that, the output transistors may be shorted.
