SOURCE: Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
SOURCE: Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
SOURCE: I need to put new turntable belt on a Technics SL-B200
The belt goes underneath the turntable platter. First you attach to the lip on the bottom of the turntable platter, then you put the platter on the turntable. You'll see some holes on the platter, after you put it on, just rotate the platter, until you see the motor shaft, then pinch the belt around the motor shaft.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
SOURCE: Changing the belt on a Technics SL-3 (Linear tracking) turntable
Instructions on installation of your drive belt - this also applies
to other brands as well - however this belt is only for the Technics
models listed above:
- OPTiC
Technics Drive Belts
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
SOURCE: Technics SL-J1 turntable drive belt
Hello Cliff,
You will need 2 belts, if the turntable belt is gone the other is not far behind . One for the turntable size 23.6 inch by .188 and one for the tracking motor that is in the top cover part, is a 3.0 inch by .046 belt. best place to get them is at kenselectronics.com part numbers 1407-201 and AV-SBS3.0 if you have been checking around you will see other sizes, I have a SL-J1 and have used these and they work perfectly.
Tony
