JBL PB12 Subwoofer Logo
A
Anonymous Posted on Dec 05, 2013
JBL PB12 woofer specifications - JBL PB12 Subwoofer
5 Related Answers
TV 954
  • 3 Answers
  • Posted on Aug 09, 2007
SOURCE: jbl PB12 powered sub woofer problem
These subs have had many problems, all associated with the amplifier section. PB 12's with an "M" as part of the ser. no. were assembled in Mexico and these are the ones with the amp problems. JBL fixed mine and sent it back no charge, BUT it cost me nearly $100 to send it to them in the first place. I have another one that has had no problems at all. Try sending it back for repair. At best you'll get a rebuilt unit back, at worst a substantial discount from the company for a new sub.
A
Anonymous
  • Posted on Jan 05, 2008
if your serial number starts with ha then it's probably a bad capacitor C72 . 6.8uf 100v np electrolytic. replace it with a higher voltage capacitor of the same value.
Monster80
Joe Lamb
  • 463 Answers
  • Posted on Apr 03, 2009
SOURCE: pb12 makes thumping sound after warming up
Hello there..Thats normal only if your sub volume and the pre amp is turned up..Your amp is the cause of the speaker jump..Turn amp volume sub level down a few and check your wire from sub to amp..If all of that is good is a normal operation for pre amp warm up in sub if level is turn to max..Try unplugging amp freom sub then turn sub on stand alone(just sub outlet plugged in and no wires from base amp plugged in..If sub stops the its the amp making the problem..If it still is there then the pre amp is either dusty on inside or the outlet plug that it is plugged in doesnt have a good ground..Hope these help to solve your problem..Have a great day...
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_a3369546f8067589
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Jan 18, 2010
SOURCE: I have a JBL PB12 the green lights are on but no
More like to have bad Class D amp module, common problem with PB-10/12. I modified my, http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
Service manuals:
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
http://manuals.harman.com/JBL/HOM/Service%20Manual/PB12%20sm.pdf
budmrtn
Bud Martin
  • 11361 Answers
  • Posted on Apr 01, 2010
SOURCE: JBL PB12 is 10 years old and I have red lights but no audio.
Service manuals: http://manuals.harman.com/JBL/HOM/Service%20Manual/PB10%20sm.pdf
My ClassD module shorted out (buzzing sound/blown fuse) and not availabled any more so this is what I did: http://s807.photobucket.com/albums/yy352/budm/JBL%20PB-12%20mod/
I would suggest to buy new one.
Jbl power module s64 ami for subwoofer pb12/230
Hi Michael.
Do you have the JBL PB 12's S64AMI Version 6.3 2000 for sale ?
Thanks
Sezai
I have a JBL PB12 sub, no power - prev wrenching sound on startup
these a internal power control board defective, send to repair
My woofer kept blowing fuses, so my friend tracked down the problem and said I need a new power coil transformer? Does anyone know what that part is and where I can find a replacement? Any help is s
You would think all these questions could be answered by your friend, right? no- contact JBL and ask for the part, its the large xformer that provides the amp with the very large amount of current it needs to drive the speaker. A local audio shop would probably have one. take yours in to have it tested, its very easy to do, they can even order it for you. good luck!
My magnet cracked on my jbl sub woofer can it be fixed
You might be able to get the manufacturer to replace it. Sub woofer repair is possible and some manufactures do offer that service, you'll have to check with them though. There is one other thing to consider- does it still work? If so you might be in luck. The magnet is there for its magnetic feild not how it looks. So if the magnetic field is un-affected and the voice coil is in one piece and un-obstructed it should be just fine. If the field is slighty out of place or not as strong it will probably affect its performance though. Good luck.
-Dynami
Jbl PB12 powered sub woofer
Top JBL Audio Players & Recorders Experts
 Grubhead
Grubhead
Bob Kirkwood
ADMIN Andrew
ADMIN Andrew
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
