General Electric GE 27"" Built-In Double Microwave/Thermal Wall Oven" Logo
J
Julie Dufrene Posted on Dec 05, 2013
Model 8006262000 Hoping someone can help me with this because I canot afford to buy a new oven/microwave. modle number 8006262000. Over did the circuit box and shut the oven off while it was in use. I tried to reset by shutting the circuit breaker off then on again but to no avail, the oven will not heat up. microwave works fine and so do the clocks. I can set the oven but it will not heat up. What can I do to fix this.
Will Giese
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Dec 05, 2013
Will Giese
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
0
Helped
2918
Points
22
I assume your oven is electric and not gas? If so, consider replacing the fuses on the oven, which are located in the back. THese fuses are pretty cheap, just ask around at the hardware store. This should fix your problem.
I Reno the kitchen. And lost the Mounting and screws for my Samsung microwave Microwave Samsung Can you help me? Modem. ME16K3910AS/AC Serial. OASS7WTHC00268F
You can get Samsung parts at affordable prices for most models from The Pros by entering your model number here:
http://tinyurl.com/gv383
How to remove ge microwave model jvm1730dm1bb from under cabinet
The installation manual for your model is located here:
http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40538.pdf
BUT in many cases, a microwave can be repaired affordably.
Need a second opinion?
Contact me directly with your model number, FCC ID number, and detailed symptoms.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
I need to find a User Manual for my DeLonghi Microwave Oven DMX30 - I hope someone can help me.
HELLO.
The best place to get the microwave oven manual guide is to visit the manufacturer website to order for the manual stating the microwave model number and give our house detailed address.
However microwave manual guide can also be purchase at any microwave oven authorized dealer around your local area with the model number for compactibility(easy use).
Thanks.
3helpful
Touch Control panel of my daewoo KOT-151S microwave needs to be replaced. I have to push control pad several times to get it to operate. Sometimes it will go on after just a few pushes, other times it...
We regularly replace these.
You can send your KOT-151S control panel assembly to us to install a new membrane keypad. The cost would be $64.95.
Or you can order an entire control panel assembly (plastic frame, stainless trim piece, keypad, and control circuit board) for $88.85, which includes return shipping.
Feel free to contact me directly (and please remind me of your model number) for more information & help.
[email protected]
http://www.microwavedisplay.com
Turntable stopped rotating.
this microwave has a turntable motor that can be accessed from under the micro.. usually a $15-30part.. put your modle number on partsdirect.com and you can see how it comes apart
Microwave will not start.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
2helpful
2answers
Replacing light bulb in Microwave Oven.
if this is a counter top modle this is no problum, unplug it!!!
open door look for the light hole vents, ( that is where the bulb is )
you will need to unscrew the outer casing. noproblum there is nothing but reguler insalation in side and a area where the bulb is. replase it you can buy them at any hardware store,
if is a under cabinet there my be a axes door if not will need to take down,
hope this helps.
p.s. 1st time i that there was all kinds of things in side but not
4helpful
2answers
Need replacement microwave to fit existing trim kit
Finally built up the courage to call GE Appliance number and weave my way through the phone menu system. Pressed the right menu option (sales) to speak to someone about trim kits. Found out that the trim kit model number is JX1527MWW. Then called back to select a different menu option (other) and learned from someone else that since the trim kit model is more than 1-2 years old, there's a slim-to-none chance any new microwave models will work with it, and even if there was they couldn't easily cross-reference against a model that old to tell me which one (or something to that effect). So I hit a dead end. Only option for me at this point is to buy a new microwave with new trim kit.
(Personal note: I think the trim kit business is a racket, in bed with the microwave manufacturers. Why else would there be no standard dimensions for microwaves by now--like refrigerators have--and why is it a few pieces of sheet metal cost over $150? Pretty convenient that every microwave model needs its own trim kit model!)
Microwave/convection oven
Does the light come on when you open the door?
It may be a fuse or thermostat or thermal cutout. These are all quite affordable repairs for you or a friend to do.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
Also at our site, we now have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Top General Electric Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a General Electric Microwave Oven Expert? Answer questions, earn points and help others
