While viewing on lcd screen it plays upside down
SOURCE: sony handycam dcr-sr40 lcd display
flip switch is not working or stucked, a loose wire connected to this switch is also possible. you may open the unit and check for it. a pro fix is better.
SOURCE: The lcd screen are flickering.
Possible that the LCD backlight circuit has a fault . In some cases the voltage generating circuit would be faulty and so the drive will have a erratic voltage therby showing up as flicker.
if you can open the LCD check for any dry soldering or loose connections, flexible strips. if not the driver board is a suspect.
