Question about Haier Refrigerators
Kegarator not working...please help!
I've got a Haier Kegarator model # H8FO5EBSS. Basically what happens is right when you plug it in the compressor hums and kicks on and after about 5-10 second the motor protector or overload switch trips and the fridge stops. The thermostat is fine and I believe/hope the problem is either the motor protector/overload switch or the relay for the compressor. The only way to get the fridge going again is to pull the relay and switch off the compressor, put them back on, and plug the fridge in again. But obviously it does the same thing every time within a few seconds of turning on. If anyone has any suggestions for anything I can do to test anything to figure out exactly where the problem is that would be greatly appreciated. Thanks again for your help. PS I hope it's not the compressor itself because that's expensive and I'm not sure I wanna spend that money to fix this crappy fridge!
    Novelist:
  • 166 Answers
Hmm, I'm no expert but since I don't see any other solutions I will give you my meager opinion. 1. In foresight you can't disconnect a compressor while it's running and reconnect it repeatedly or you will fry the compressor, especially in bigger units. A period of 15 minutes should be given to let the gasses convert back or the compressor works overtime. Same reasoning when moving a fridge to not lay it down but if necessary allow the fridge to remain upright for a while prior to operating. For the temperature relay, it is a black on one side, and aluminum on other, 4x a nickel - sized coin shaped looking thing that is a safety feature and it is on the compressor for overheating shut off. This typically wouldn't allow you to hear anything once burnt or shorted so the compressor wouldn't work at all. Therefore I suspect the Capacitor or compressor in this case and be careful to short it out with a plastic handle screwdriver once unit is unplugged as all capacitors retain power and will give u a jolt if not more serious :(_ I would seek a used capacitor from a junk fridge these are typically located under a black cover on the compressor as well and look like a small soup can. Take pics of the wiring for reconnecting and be sure not to contact the ends of the capacitor until you shorted it out as described above. Capacitors can be tested with an ohm meter but is not an accurate test. Try to get the right measuring capacitor for replacement and the amount of farads next to the voltage on side of capacitor is more important than a voltage as long as voltage isn't lower than the original. Also a capacitor is polarity sensitive so don't mix that up. Not sure if I answered your question but may have given you ways to solve them.
Posted on Dec 05, 2013
SOURCE:
  • 1462 Answers
SOURCE: Refrigerator not cooling.
compressor has failed. not a diy job
Posted on Apr 25, 2007
the dr
  • 447 Answers
SOURCE: Side by side stopped working but clicling noises every second two.
Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
Posted on Dec 02, 2007
  • 236 Answers
SOURCE: Kenmore compressor cycles and does not cool
It sounds like you have a stuck compressor or bad start capacitor.
Stargazer
Posted on Mar 16, 2008
SOURCE: Hi, The Earth Leakage Breaker (ELCB)
what is elcb
Posted on Nov 16, 2008
  • 998 Answers
SOURCE: Fridge compressor strarts up but turns off after a few seconds.
replace compressor
Posted on Aug 08, 2009
Where is controller knob on freezer
Brenda, haier freezer control quite often front lower right corner, some may be behind freezer by compressor, check the links to see if you can find your model and manual. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://image.haier.com/manual/southeastasia/haier/freezer/chestfreezer/201203/P020120309357074931017.pdf
Haier Freezer manuals
Haier Freezer controls Google Search
Jun 12, 2016 | Haier Freezers
My avanti kegarator not cooling good. Added freon, now warmer than before. Any suggestions?
Most compressors are picky about the amount of freon (and certainly the type of freon. After verifying the type of freon, rent a pressure gauge and check that the right pressure is in the low an high side. That should also help you diagnose if it is a bad compressor.
Jun 06, 2014 | Avanti Refrigerators
Haier 5.3 Cu ft Chest freezer. power is on but compressor doesn't run. There is click sound but nothing happens after.
The click sound is the compressor starter relay closing but if nothing further happens it is likely that there has been a compressor failure
Apr 11, 2013 | Haier 5.3 cu. ft. Chest Freezer HNCM053E
Deep freezer not freezing food and keeps making a clicking sound.
Even a sealed unit could need recharging with R134a refrigerant.
Dec 29, 2017 | Haier Refrigerators
I have a Haier wine cooler BC112C. The compressor will not kick in (but I can hear the relay switch engaging) unless I plug and unplug the unit 4 or 5 times, then the compressor cools to the proper...
Hi!
That is probably the compressor relay
The relay is on the compressor and needs replaced
A relay starts the compressor with a higher voltage and then quickly kicks out
Thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Aug 10, 2011 | Haier BC112G Wine Cooler
Compressor is shot cycleing..worked fine 1 week ago thne not used for a week but cycleing on and off
Hi!
That is probably compressor relay.
The relay is out on the compressor a. Needs replaced
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Haier CPRD12XH7 Air Conditioner
I have a Haier model BC112G that stopped working. I unplugged it overnight and it still won't work. It just makes a clicking sound once in a while. Any Ideas? Wayne
Sounds like you compressor won't come on, check you warranty status before you call anyone. This repair can cost more than the unit did. The clicking noise is the overload on the compressor witch will happen if the relay fails (rare on this unit) or the compressor locked up. Either way, check warranty status on you unit before you call anyone, maybe cheaper to replace unit.... I hope this helped..
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Jul 11, 2011 | Haier BC112G Wine Cooler
Haier aficionado model AES44BPG compressor wont stay on
I had the same problem. Mine turned out to be the PTC starter. Checked the compressor coil resistance and it ws fine. Replaced the PTC starter with Item #: 1268268 from Repairclinc.com and it started right up. The PTC starter was an exact replacement.
Hope this helps some else trying to solve this problem. To bad Haier doesn't offer this part!!
May 01, 2009 | Haier (B000194UBA) Compact Refrigerator
Refrigerators Logo
50 people viewed this question
Top Haier Refrigerators Experts
Vernon Taylor
John Tripp
John Tripp
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
