try to use the menu buttons of the display/screen to reset it to factory defaults and use the auto-adjust option if available. this often resolves common issues specific to the screen itself. it can help help to remove the power cord from the monitor then hold its power button for about 10 seconds to drain any power and test it again using another video cable. you may also want to observe if it flashes when not connected to the video cable and when plugged in to a different power outlet and cord.
Press the flash button (just under the viewfinder) to cycle through the flash settings. Your choices are Auto Flash, Auto Flash with Red-eye Reduction, Flash On, Flash Off, and Night.
If you want to capture the screen image, you're better off using the computer operating system's screen-capture capability. This will give you the screen exactly as it is, without the distortions inherent in converting to an analog image and then converting it back to a digital image.
Well try to go in menu after 20 min (warming up) after powering ur monitor & try to adjust or U may need to press a button on ur monitor to disable the message...
for e.g viewsonic screen is button num 2
First of all, the flash can not be turned off in "Auto" mode. You can turn it off in any mode other than Auto. Would recommend Program "P" mode, which is very similar to Auto, but allows you to modify certain minor items such as flash and white balance.
Rotate your mode dial to "P", then press the button on the back with the "lightning bolt" icon. Press until the lightning bolt with a slash shows up on your LCD screen. The flash is now turned off in Program mode. Try taking a picture.
Remember, if in low light conditions you'll need to keep the camera extra steady without flash to get a clear picture. Recommend placing the camera on a table or chair (or even better, use a tripod), then using its autotimer to snap the picture.
Check the playback menu that the review time has not been set to OFF. This will stop any pictures displaying on the back of the camera when taking them!
I leave mine at 2 secs which is long enough to quickly review and keeps the battery life up. If I need to review for longer, just use playback.
The flash won't come on if you have the camera in any of the creative modes (i.e. A-DEP, M, AV, TV or P). You can manually use it by pressing the flash button just above the lens release button on the front of the camera.
Check your settings in "Power Options Properties".
Control panel/ power options/ advanced/ under power buttons make sure you have "shut down" when you press the power button on your computer.
I hope I am understanding your problem correctly. If not pls. explain what you mean by and when processing auto config. keeps flashing. Is there a black screen or a windows interface?
the VCO IF transformer has change value..,it need to adjust using plastic or wood stick,it is looks a metal cubes near the jungle IC or eles try to resolder the tuner
