I am having Motorola L7, whenever i press any key on my keypad, menu key is automatically pressed and it shows "shortcut is not allowed". even when i pressed volume key and camera on key, every time it shows "shortcut is not allowed" What to do?
Create a shortcut
Open the folder or directory that contains the program you wish to create a shortcut for.
Right-click on the program and click Create Shortcut.
This will create a shortcut named "Shortcut to <your program> in the directory you are in. If you wish to rename this shortcut, right-click the file and click rename.
Once the above steps have been completed, you can copy or cut this shortcut and paste it anywhere to execute this program.
Assign shortcut key to that Windows shortcut
Once the shortcut has been created to assign a shortcut key to that Windows shortcut follow the below steps.
Right-click the shortcut and click Properties.
Click the Shortcut tab.
Click in the Shortcut key box and press a letter. For example, if you press "p" the shortcut key will automatically be made Ctrl + Alt + P. Which means if saved when pressing Ctrland Alt and "P" all at the same time will run that shortcut.
Shortcut Keys Description Alt + F File menu options in current program. Alt + E Edit options in current program F1 Universal Help in almost every Windows program. Ctrl + A Select all text. Ctrl + X Cut selected item. Shift + Del Cut selected item. Ctrl + C Copy selected item. Ctrl + Ins Copy selected item Ctrl + V Paste Shift + Ins Paste Home Goes to beginning of current line. Ctrl + Home Goes to beginning of document. End Goes to end of current line. Ctrl + End Goes to end of document. Shift + Home Highlights from current position to beginning of line. Shift + End Highlights from current position to end of line. Ctrl + Left arrow Moves one word to the left at a time. Ctrl + Right arrow Moves one word to the right at a time.
