that is strang, both ovens with the same problem?
of course it could be the thermostat for both ovens, but it is not likely.
The first link shows you all the parts of the lower oven.
It has 2 elements. If one has gone and that one is not replaced, then nothing will change
Frigidaire Washer GLEB27T8CBA Parts List
The upper oven also has 2 elements.
Often the base element is gone first.
When you husband did not notice that, and both the base elements are gone, then indeed nothing will change
I hope this helps and I wish you succes, Dik
SOURCE: Oven not heating to correct temperature
First thing that should be checked is proper voltage. Low voltage can cause this problem. Have that checked by a professional first then let me know what you find.
SOURCE: GE Electric Range
It is very common for elements to "catch fire" when they fail. It is really electical arching. But to answer your question you shouldnt be concerned if it ever happens to the bottom element immediatly kill the breaker it will stop instantly. dont use a fire extinguisher as it wont stop the arching. And most ovens do use the upper broil element for baking for very short intervals like 10secs on every minute or so to brown the top of product. Some models (especially older builder line ) do not
SOURCE: GE Electric Spectra Oven botton element will not heat
If only one element does not work, then test heating element continuity using a multimeter.
If oven does not bake or broil, then test temp
probe.
If there is nothing wrong with elements and temp probe , then test wiring harness to
control panel and timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Thank you for your inquiry, Bego?a Rebolledo-Kaufman!
From the information you have provided you are experiencing an issue with your Frigidaire double oven not heating. It sounds like a possible problem with your element or thermostat. I would suggest to perform a reset on your range, to see if that would help correct any miscommunication within the electrical components. In order to reset your range you would need to flip the household circuit breaker off for ten minutes. If you still continue to have an issue with the oven I would recommend having a professional technician out to provide an accurate diagnosis and replace any electrical parts needed inside of your oven. Hopefully this is helpful to some degree. -Matt
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
