There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
SOURCE: Stuck in Game Mode!!
I have the opposite problem. I don't have the remote, it broke, and I'm stuck on channels when I want to play a game. How do I fix that without the remote?!
SOURCE: Help with Game Mode/Channel Switch Please!
there is this remote set up like a dvd remote and it has 3 or 4 diffrent ways to get into the game mode
Notes about using USB
= Before using this function, make sure that you select the correct source (USB) and insert a USB storage device on
the TV to view compatible photo, movie and text on the TV screen or play compatible music through the TV.
= If the connected USB HDD does not have an external power source, it may not be detected. Be sure to connect the
external power source.
= To avoid losing the data on your USB device or damaging your USB device, it is recommended that you back up your USB
device data.
= The USB multi media playing menu may vary in different situations.
= If you want to pull out the USB device, please exit USB mode first.
= For instructions on using your USB device, refer to the owner's manual for your USB device.
= Never remove the USB device or turn off the TV while using the USB device. Doing so may result in loss of data and/or
damage to the USB device and/or TV.
= Certain types of USB devices may not be compatible with this TV.
page 21 also shows hitting USB button on remote (lost that?)o
and see photos on a USB or a movie. Photos , movie or text it tells.
here is my wild guess on the model.
https://www.manualslib.com/manual/918457/Sinotec-St-29me70h1.html?page=23#manual
the TV has multimedis player inside, this works for USB.
page 26 covers what movie FILE formats work.
format the usb stick as Fat32 is one safe first guess and try.
good luck with using USB. (the manuals on TV are very very limited on (what it needs to work right)on this TOPIC.
one poster back 2014 this brand
tells. supports fat16/32,and NTFS. and JPG,PMP and PNG photos. and what page 26 tells you,.
