New replacement in-line heating unit does not turn on/get warm to the touch, etc. The part NBR: C3B54P0-3002AU0, was purchased from a local vendor which ordered the replacement heating unit. The original heating unit, Part Nbr./ Model Nbr. was: C3B5341-3002AU0. The replacement heater does not get warm to the touch, and does not "turn on" . I think the problem may be due to the settings selected on the tub's control panel. The water temperature stays at 69 degrees F. and the unit never gets warm. Do I have to fill the tub with warm water at the start for the heater to operate properly ? Is there a "trick" selecting the tubs settings which will allow the heater to heat ?
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
SOURCE: hot tub mtor is on.....no jets....
you may have burnt the pumps up,pumps like that are water cooled they may have over heated ,you may need to replace the pump.
SOURCE: Our Max jetted tub won't
see if ther is another panel arond tub,there may be another breaker,try resetting breakers turn off the back on,see if this works
SOURCE: I have a maax hydro
Hi, the in-line water-heater temperature feature is designed to sustain the water temperature by automatically turning on when the whirlpool pump is activated.
SOURCE: I can not find my
From what I found, it seems like that is normal. The light tells you the water is high enough to operate the whirlpool if you desire. If the light bothers you, you could turn the circuit breaker off for the whirlpool. That would also protect it if you get power surges.
SOURCE: Maax tub LM65519 control panel has broken lines running through
Broken lines where? are you referring to broken water lines or the actual control line?
rod
us parts center
