Question about Konica Minolta bizhub C250 All-In-One Laser Printer
C9401 bizhub c224 - Konica Minolta bizhub C250 All-In-One Laser Printer
  • Konica Minolta Master
  • 6,850 Answers
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Posted on Mar 25, 2018
3 Suggested Answers
SOURCE:
  • 51 Answers
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
Posted on Aug 30, 2009
fivemayur
  • 414 Answers
SOURCE: what side goes up when loading originals
top of mirror
Posted on Aug 30, 2012
Knoica Minolta Bizhub C224 fuzzy images but text is clear
the file may be corrupt try different files
Mar 22, 2017 | Konica Minolta Bizhub C224 Color Copier /...
Four green lights lit up on front
where on the c224
Feb 10, 2014 | Konica Minolta Bizhub C224 Color Copier...
I have a new bizhub C224 when I print color is OK but when I copy color there is magenta lines or cyan lines and only in copy and the demo page is ok too
Problem with the scanner (Thing that move as it scans has the bright light and mirrors on it. Or the CCD that is the black device under the big glass on the right, get a tech out to clean and or replace
Dec 26, 2013 | Konica Minolta Bizhub C224 Color Copier...
Bizhub c224 cod c9401
Dec 04, 2013 | Konica Minolta bizhub Office Equipment &...
C224 exit jams
does this machine have a finisher? exit jams where after fuser?
Nov 13, 2013 | Konica Minolta Bizhub C224 Color Copier...
How to solve konica minilta c224 machine c2558 error
SHAKE THE BLACK IU VERY WELL Clean Imaging Unit Contacts RUN GRADATION
UPDATE FIRMWARE
REPLACE BLACK IU
Jun 29, 2013 | Konica Minolta Bizhub C224 Color Copier...
Our machine shows C9401 default, can you help us in solving this problem
Not exactly sure if the model is the same but on a C351 the C9401 & C9402 errors are as follows:
16.6.81 C9401 Exposure lamp failure to turn on
16.6.82 C9402 Exposure lamp turning on at abnormal timing
Parts to check:
Scanner Assembly
Flat Cable
Image Processing Board (PWB-C)
Step Action
Corrective steps in order of suggestion:
Check flat cable for proper connection and correct or change as necessary.
Change Scanner Assembly if necessary
Change PWB
Apr 29, 2010 | Konica Minolta bizhub C450P Laser Printer
adjustment.
Change PWB-C.
Aug 03, 2009 | Konica Minolta bizhub C351 All-In-One...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
