APC Back-UPS 400VA (BK400) UPS System Logo
Posted on Oct 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
APC back UPS 400 fails to give back up
I have 3 year old APC back UPS 400 i changed the old batteries and put new batteries 6 months back. now when my power goes off my ups doesnot give back up and my system goes off as soon as there is power cut. what is the problem
  • 1 more comment
  • chod Oct 12, 2007
    i have 3 year old APC back UPS 400 i changed the old batteries and put new batteries 6 months back. now when my power goes off my ups doesnot give back up and my system goes off as soon as there is power cut. what is the problem
  • anke Jun 18, 2008
    Our 2 UPS models need to be re booted after mains goes off.
  • a12josephr Feb 22, 2009
    my back-ups 400 sutdown when the house goes out. how can i fix the problem the slaft test work's fine. and the power works fine it.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 16, 2007
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1101
Points
I have the same problem with an apc smart-ups VS 650.
New batteries - charge in batteries is good (also tested under load).
When AC power fails, no power is supplied to PC connectors by the UPS.
UPS self test works fine. UPS does not report any problems via software - Power Management under Windows XP.
A
Anonymous
Dear fixya...i'm using Pioneer UPS 500..I'm not able to get backup even after changing my old battery...but after changing my battery...I've chaned the adjustments of presets which are of 10K...tell me how to do the adjustments in correct manner
sandeep deol
SHIVAJI YADAV
Level 2:
Habit-Forming:
  • Expert 188 Answers
  • Posted on Oct 13, 2007
SHIVAJI YADAV
Expert
Level 2:
Habit-Forming:
Answers
188
Questions
Helped
97860
Points
329
I think u have problem with u r battery...
may be not working properly..
change u r battery and then try again...
dont forget to tell me u r problem solved or not
best regards & best of luck..
even u can mail me at my mailing add- [email protected]
  • SHIVAJI YADAV
    SHIVAJI YADAV Nov 05, 2007
    hey dude.....u did not make any repley....for u r problem solution ...
    hope it is solved.......
    Was this solution helpful? Show your Appreciation by rating it:
    pls vote for me man..& IF U R PROBLEM IS SOLVED RATE MY SOLUTION AS SOLVED
1helpful
I have an APC ES-350 hooked up to a flat screen tv with amplifier and a radio. The tv and amplifier were on and all of a sudden there is a steady continual alarm coming from the ES-350. We've only had...
Yes there are replaceable batteries but if yours is only 6 months old and was new this should not be the problem. That said, batteries only have a certain lifespan from the date of manufacture. If it sat on a shelf for a long time before it was sold the battery could be junk.
Is the tone continuous? If so this is the overload alarm.
2helpful
3answers
Smart apc ups error with all indicator flashing .
APC Smart-UPS 1500VA has an error. All it's pannel lights blinking. what is the best possible solution to this?
2helpful
APC passes its self test but no backup
More than likely it is the battery. These units simply test the voltage during the self test, and, although not typical, the battery voltage could be good without a load, but fail with a load. 3 years is generally the life span of SLA batteries. Replacement batteries are fairly inexpensive and can be found at: http://batteryinternational.com/ups-batteries-apc-batteries.html
Ups not giving back up
How old is this UPS? Is power failure frequent? Anyway I think you batteries will be gone faulty. You may have to replace them.
1helpful
APC Back-UPS ES 350 - when powered on has a blinking green light Is this normal
A blinking green light is likely an indication that the internal battery is nearing the end of its usable life cycle. If it's over 3 years old this is likely the case. To test, plug something in to the battery outlets and pull the plug of the UPS from the wall. If you get a short runtime (or none at all) it's the battery. Batteries are under $20 and can be found here: http://www.batteryinternational.com/apc-backups-es-be350u-ups-battery-ups-batteries-f1.html
2answers
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
1helpful
2answers
APC Smart UPS 1500 will not start.
It could be that the cable to the front-panel got damaged during the battery replacement.  After all these years you would think APC would improve that aspect of their design.  All I can suggest is inspecting the cable and where it connects to the front panel.
Less back up time
I found the following on APC's web-site for the APC Back-UPS, this will hopefully fix the problem:
You can also perform a manual runtime calibration. This could be done if you have changed your equipment load or battery. Stop the PowerChute software from running; disconnect the serial cable between the computer and UPS. Next unplug the UPS from the wall and let it run on battery until it reaches low battery. Once it reaches low battery plug it back into the wall outlet and let it recharge. Recharge time can take up to 4 hours.
from link: http://nam-en.apc.com/cgi-bin/nam_en.cfg/php/enduser/std_adp.php?p_faqid=2819&p_created=1048797826&p_sid=tANR-rxj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NCw0JnBfcHJvZHM9MCZwX2NhdHM9JnBfcHY9JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yZWNhbGlicmF0ZQ**&p_li=&p_topview=1
2answers
Low battery alert on my apc - ups es350
Have your supply voltage and frequency checked under load.
/bz
Top APC Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
