Power Acoustik PTID7002NR Car DVD Player Logo
Donald James Posted on Dec 05, 2013
Bvb not playing - Power Acoustik PTID7002NR Car DVD Player
2answers
I have a 1986.5 Nissan truck with z24 engine; the idle is rough; is there a remedy without replacing throttle body?
Take off the air filter housing and there is a hole about 3/8 of inch round the air flow sensor is down in it .they get thrash or bvb a bug in them and cause poor idling
tip
Unlockable Characters
Ness- Reflect ten projectiles in battle or play 5 vs matches
Marth-Beat classic mode or play 10 vs matches
Luigi-Beat classic without using any continues or play 22 vs matches
Falco-Beat 100 man brawl or play 50 vs matches
Captain Falcon- Beat classic mode in less than twelve minutes or play 50 vs matches
Lucario- Beat him in adventure mode with Meta Knight, beat five target tests or play 100 vs matches
Snake-Play 15 matches on Shadow Moses island or play 130 vs matches
ROB-Get 250 different trophies or play 160 vs matches
Ganondorf-Beat classic or hard with Link or Zelda or play 200 vs matches
Mr. Game and Watch-Beat target smash with 30 players or play 250 vs matches
Sonic-Beat classic with ten characters, play for ten hours or play 300 vs matches
Jigglypuff –Beat event match #20 or play 350 vs matches
Toon Link- Beat Subspace Emissary than classic with any character or play 400 vs matches
Wolf-Beat Subspace Emissary than boss battle with Fox or Falco or play 450 vs matches
Zero Suit Samus- Hold R on a Gamecube controller or minus on a Wii controller while selecting Samus.
Sorry everything is underlined, something is wrong with my computer
2answers
Google play server not working trying to sign into g.mail says try again later
Why is Google Play not working?
The bad part is that sometimes older data can pile up, and it can also misbehave. This is why it's good to clear cache from time to time. To wipe the Google Play Store cache memory, just head over to your Settings and select the "Apps" option. From there, simply look for Google Play Store and tap on it.
Google Play Store not working? Here are some possible fixes
www.androidauthority.com/google-play-store-not-working-fixes-647176/ Search for: Why is Google Play not working?
Google play server not working Google Search
5answers
How you play rummy? with whom do you play rummy?
Rummy! I always used to play it, every week i play rummy with my buddies at pokabunga the best online rummy games in the India.
https://www.pokabunga.com/online-rummy-india
Dec 14, 2015 • Games
How can i watch video from Samsung s1050 in my computer?
Hi, Here is the procedure on how to play the video clip on your camera. Play mode If you have turned on the camera by pressing the POWER button, you can press the PLAY MODE button once to switch to Play mode and press it again to switch to Recording mode. You can turn the power on with the play mode button. The camera is turned on in play mode. Press the play mode button again and the camera will be turned off. You can set up the PLAY mode function by using the camera buttons and LCD
monitor. Playing back a still image
1. Select the PLAY mode by pressing the play mode button.
2. The last image stored on the memory is displayed on the LCD monitor.
3. Select the recorded movie clip and press the Play & Pause button to play back.
- To pause a movie clip file while playing it back, press the play & pause button again. ac0dd93.png
- Pressing the play & pause button again will cause the movie clip file restart.
- To rewind the movie clip while it is playing, press the LEFT button. To fast forward the movie clip, press the RIGHT button.
- To stop playback of the movie clip, press the play & pause button, and then press the LEFT or RIGHT button. 0e83d9c.png
Bvb
BVB Being Very Blunt, I am telling you to find a repair sho[p to replace your LCD screen.
23HCV87 DVD problems
May be dirty lens get a cleaning disc for cd player and insert to clean then try player again. If you can take cover off insert disc see if disc spins,if not spinning you need a motor drive.
Top Power Acoustik Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
ZJ Limited
ZJ Limited
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
