Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Nordictrack Commercial 1500 treadmill w/working display BUT unresponsive buttons
Treadmill and display come on with belt moving slowly, but won't respond to buttons being pushed. A beeping sound occurs when the buttons are pushed but no change in speed, incline, start, stop, etc. No buttons work. Belt will only stop if the red safety key is pulled or if main on/off switch on bottom is hit.
    Problem Solver:
  • 15 Answers
Sounds like a cable harness is undone. The cable feeding the panel which has the computer inside (the power feed) is connected, but the cable from the panel back to the motorized parts isn't. The breakaway is a separate circuit that cuts all power to everything. These are my assumptions (I'm not a nordic track expert), but it's a pretty safe bet, likely the connector in the bottom section. Okay, I just looked it up, first Google "nordictrack 1500 manual" one of the first links is a PDF, with a complete parts breakdown. Depending on your specific model, it looks like there is a connector under the top panel where it meets the right post (and a couple of screws will let you lift it up to check it). It may be partially unplugged, check that first since it looks pretty easy to check.
But I think it's going to be in the bottom, in the bottom of the treadmill the wiring splits to different sections. The motor/incline controller cable (a separate cable #106 on one model I looked up, something like NTL09707 or similar) is probably the one that is either broken or unplugged. So although the computer (up top) is sending signals, they aren't reaching where they need to. Anyway, get that manual, and someone handy with screwdrivers and technology, and they should have it figured out quickly.
Posted on Dec 04, 2013
  • Elizabeth
    Elizabeth Dec 06, 2013
    Much appreciated christexan, will try what you suggested! Thanks for taking the time to help. :)
    New Friend:
  • 338 Answers
Also there could be a problem with the console.
Posted on Dec 08, 2013
2 Suggested Answers
SOURCE:
ercupa190
  • 12223 Answers
SOURCE: Nordictrack COmmercial 1500 console buttons don't work
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnes
11_17_2011_8_43_24_pm.gifsincerely. Please keep me in touch.
Posted on Nov 17, 2011
I have a NordicTrack commercial 1750 treadmill. My console contols do not work and the ifit screen does not complete startup. What can I do to troubleshoot the problem?
The Controls Are Not Working on a NordicTrack Treadmill ...
www.livestrong.com > Sports and Fitness
Jun 1, 2015 - The Controls Are Not Working on a NordicTrack Treadmill ... Many glitches involving the controls on the console can be solved relatively quickly with some simple .... How to Use the iFit Videos with My NordicTrack Treadmil...
Nordictrack commercial 1750 that Icon can NOT fix - YouTube
? 3:52
https://www.youtube.com/watch?v=ILBbzyUXn2Q
Dec 16, 2011 - Uploaded by gerg6060
Nordictrack commercial 1750 that Icon can NOT fix ... I'll NEVER buy another Nordictrack again, Smooth or ...
[PDF]View Manual in PDF Format - NordicTrack
https://service.nordictrack.com/.../pdfDownload.do?...1...
NordicTracktreadmill is not working properly. (See. TROUBLESHOOTING on ... COMMERCIAL 1750 treadmill. ... Console. Book Holder. Key/Clip. Power Switch. Walking Belt. Foot Rail. Power Cord ... Set the treadmill in a cleared area and remove all packing materials. Do not dispose of .... Each workout automatically controls the speed.
Dec 28, 2015 | Nordic Track NordicTrack COMMERCIAL 1750...
Display
this could be the LCB .But this year I have replaced quite a few consoles.Usually with this brand if the console buttons don't work it is a console,but if power isn't getting to the top it will be the lcb.
I repair this brand for the supplier in Australia.
Mar 13, 2014 | Nordic Track NordicTrack COMMERCIAL 1750...
Nordic track commercial 1500 no power
looks like there is power to the board. the board the sends power to the console. there could be a loose connection at the board
Mar 04, 2014 | Nordic Track NordicTrack Commercial 1500...
Nordic track 1500 treadmill with no display and there is only a red blinking light on the circuit board
1( tight the ribbon cable and clean it,
2) tight the plug from display board , and clean it.
3) tight the display board vs lower board and clean it unplugged the power
4) test the fuse and replace if necessary or c.breaker reset.
5( Finally adjust the REED SWITCH , clean it and tight the plug very well see the diagram attached.
6) see the block attached. finally the display board can be faulty.
God bless you
Sep 30, 2012 | Nordic Track NordicTrack Commercial 1500...
Nordictrack Commerical 1500 - Display Failure/Won't Turn On
There can be a few reasons,
Lume
LCB
Console
Is it under warranty ?
Jan 25, 2012 | Nordic Track NordicTrack Commercial 1500...
Nov 17, 2011 | Nordic Track NordicTrack Commercial 1500...
My Nordictrack commercial 1500 is stuck at 12% incline and won't go nor up or down. How do i fix?
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
Sep 12, 2010 | Nordic Track NordicTrack Commercial 1500...
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
442 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Treadmill Repairs...
Android Man
Android Man
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
