1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Reset key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: Konica bizhub C351 with a C9401 error code
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
SOURCE: Bizhub c300
microsoft wiondows xp professional version 2002 servicepack 3 software needed for model no M1005 LASERJET SCANNER PRINTER
Once in service mode do a STOP, 0, C
You should then have an option to reset admin password
The manual has these steps to reset."
