Once it uses the fuel pumped in via the primer button it stops running. I can pump it 15-20 more times and it starts right up but as soon as that pumped fuel is burnt up it dies again. The fuel line looks fine, the fuel filter also looks ok. When priming, where is the primer getting fuel from if not the fuel line that's visible? Is there another line it gets it's fuel from?
SOURCE: white vert lines 1 inch apart, toshiba rear projection
From further research it sounds like you experiencing a failure of your DMD board. Here's a forum dedicated to the topic of your television.
http://www.avsforum.com/avs-vb/archive/index.php/t-438276-p-7.html
SOURCE: The convergence going bad again on my Hitachi 51swx20b
Sounds like loose solder on the chips. Either that or they are failing. You can save money next time by doing it yourself with a kit from www.TvRepairKits.com
SOURCE: I get a message to
hi,
To clan the air filter you have to remove the projection unit.You can see the projection unit behind the lamp blast board.There are three air filters in this unit. You have to clean these air filters. I have added the picture which showa the location of air filters. If you can give your email address the i will sent the service manual. Which will help you to remove and clean these Air filters. Remember one thing remove lamp first then only remove the projection unit from the rear side.
OK
Not sure why it posted this to Projection Televisions.... Please move to the appropriate category!
