Fresh out of the box - My player just says "starting" on the display - it isn't showing anything on the TV through the HDMI inputs or through the AV inputs. I've tried all the HD inputs on my TV as well as the AV just in case. My previous player works on all inputs.
Brand New? Send it back !
First go step by step through the instructions to make sure you hooked it up right.
Still not work? Return for exchange or refund!
Connecting your old RDR-HXD890 player/recorder to your Sky Q box and TV can be done by using the appropriate cables and connections. Here is an example of how you can connect the devices:
Connect the HDMI output of the Sky Q box to the HDMI input of the RDR-HXD890 using an HDMI cable. This will send the video and audio signals from the Sky Q box to the RDR-HXD890.
Connect the HDMI output of the RDR-HXD890 to the HDMI input of the TV using an HDMI cable. This will send the video and audio signals from the RDR-HXD890 to the TV.
Connect the aerial cable to the aerial input of the RDR-HXD890
Connect the RDR-HXD890 to the power outlet
Turn on all the devices and set the TV to the HDMI input where the RDR-HXD890 is connected.
By connecting your devices in this manner, you will be able to watch and record TV shows and movies from your Sky Q box through the RDR-HXD890 and display them on your TV.
Corrupted firmware. A firmware update is necessary. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Did you ever find a solution to this problem? I have the same model TV and I cannot get anything to display from a DVI video source. Anything "pure" HDMI like a DVD player, XBOX 360, or media streamer, work fine. I now have a PC connected to the TV. The PC has an HDMI port and works fine on 2 LCD TVs I have at home but not this one. I'm starting to think it's a wierd HDCP thing.
Try rebooting your laptop while the TV is on and select the correct input with your TV remote.
If that does not work, trying going into display properties in the Control Panel and setting up your TV as a secondary display from there.
- Start > Control Panel > Display Properties - Settings Tab - Right click on grey box next to blue box and select "Attach" - Click Apply and restart your computer.
My HT-S6100 had a similar problem with my DVD player and some times with my Cable/DVR box. The signal wasn't getting received at the TV. So, first I changed the input jacks my DVD and Cable box are plugged into on the receiver (e.g. from HDMI 1 & HDMI 3 to HDMI 2 & HDMI 4). Second, I reprogrammed the Input Assignments to match (e.g. HDMI in 2&4). Third, I deleted any Input Assignments that weren't applicable. For instance, I'm only using HDMI connections, but there were Digital and Component Input Assignments programmed in. When I say I deleted them, I actually set them to "----" (just scroll through the options and you'll find this.) Finally, I turn on my video/audio sources (PS3 in your case) and let them load/warm up before I turn on my Onkyo receiver. It seems to be working. Good luck.
Everything I've read on the web says cable box to tv connection must also use component (rgb) cables. The error is coming from the cable box (STB). All the Scientific Atlanta (SA) cable boxes seem have this Digital Rights Management (DRM) bug and the only way to be totally rid of the error is to replace the digital connection from box to the TV with an analog connection.
Make sure none of the Digital or Component Input Assignments are programmed, if you're not using them. Set them to "----". This may help. Some of the Component input assignments may over-ride your other input assignments (perhaps even the HDMI input assignments).
Most LCD displays have an input select button to choose the TV ot PC display. You just press the button and it cycles thru the options. Normally starting with VGA, then DVI and then the remaining input options.
