Check your Phone if connected to Jack 01 to do programming below:
on KX-T7730 phone Press Program *# (enter Password) default is 1234
Press 400 SP-Phone(CO NO.? will be displayed) Press *(Mixed or Connect will be displayed), Press AUTO ANS/MUTE untill (NOT Connect will be displayed) Press AUTO/STORE. Press HOLD(SYS PGM will be displayed) Press 400 (CO Connection will be displayed) Press SP- Phone(CO NO.?) Press SP-Phone (Not Connect will be displayed) Press AUTO ANS/Mute until (Connect will be displayed)Press AUTO/STORE PRESS PROGRAM to return to NORMAL Display.
For the incoming Calls PRESS Program *#1234 (ENter Sys PGM will be displayed) PRESS 408(Day IN CO will be displayed) Press SP Phone (CO No? will be displayed) Press SP Phone (CO1:#01:DISABLED if this is displayed PRESS AUTO ANS/MUte the Enabled will be displayed) Press AUTO/STORE. Press Program to return to normal display. In this Manner All Calls will ring to extension which is connected to Jack 01. you dont need to press the button anytime there is an incoming call.
SOURCE: I need help programming the phone to pick up CO1
This is a guess because you still didn't tell me what system you're connected to. On an idle phone, try pressing PROGRAM 131 STORE. In a TA-824, that makes you select line 1. If it's busy, nothing happens.
Carl
Testimonial: "That worked!!!! Thank you SO MUCH!"
SOURCE: i had a KX-T7730, i
From the idle phone, press PROGRAM the button where line 1 used to be and dial 0 1 STORE do the same for line 2 if you unprogrammed that, using 2. Press PROGRAM or pick up the handset and drop it back down to end programming
Carl
Testimonial: "thanks for the help! it was exactly the help i am looking for! cheers! "
SOURCE: How to program ring tone
i have 16 telephone there are 8 of it has not ring .how can i fexed it?
