The tv is making loud noises like humming or motor noises and tv have strange colors flashes or black and white backgrond flashes.The tv Colors wheel it is dying and not spinning the right speed of it RMP speed any more.The tv colors wheel must have be replaced to solved this problems.Have no mechanicals skills hire a tv tech. to change the tv colors wheel because u have to take out alot of mechanical parts out before u can come to the tv colors wheel itself to replace it.
The loud noises came from the tv with a colors wheel design in it have to be replaced every few years,because the spinning of the colors wheel disc are spinning in very high speed in RPM to have it colors for the tv to operate correctly,the humming,loud motors noises and eventually the effect of the tv colors.The colors wheel disc are worn out and spinning hitting it axes motor,the colors wheel must be replaced to solved this problems.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Bad Color Wheel, its located behind the Lamp Pull Lamp out and use a Flash Light You should be able to see it.
Encompass Parts Distribution 1-800-638-3328
Samsung Parts.com 1-800-627-4368
You can also go to Encompass website and look up your Model#
g/bp96-01579a.php Part # is BP96-01579A and you can find it here: http://www.discount-merchant.com/Samsung-Replacement-Color-Wheel-HLS-HLT-Series-p/samsungcolor_wheel_bp96-01579a.htm?Click=48173 Have a blessed one!
Hi,sounds like you might be experimenting a color wheel problem.The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Your part # is BP96-00250A You can find it here http://www.discount-merchant.com/Samsung-BP96-00250A-ColorWheel-Assembly-p/bp96-00250a-color-wheel.htm?Click=48173 and here's the instructions to replace it : http://www.fixyourdlp.com/guides/samsung/bp96-01579a.php Have a bless one!
Yes you can repair this your self it is the color wheel also keep in mind that if set does not play after replacing color wheel and lamp lights,color wheel working with all 3 fans running and set shuts off within 30secs of turn on BAD LIGHT ENGINE!!!!!!!! also they are NO LONGER Available cost of that part was 1,000.00
Sounds like your color wheel may be at fault. Do you ever hear any unusual noises coming from the rear of the TV? Color Wheels usually make a humming sound as they go bad. This is because the tiny bearings in the color wheel motor have begun to misshape from use and heat. This is a known issue in this TV! Expect to spend $300-500 to have this serviced by a service company. If you have the right stuff, you can do it yourself. If you search the web, you'll find a color wheel for this TV for under $100, but installation can be tricky.
