Phone wont boot, held down power button and bottom buttons light up 15 times and then vibrates. tried to reset it by using "volume down and power button" and nothing happens. hooked phone up to computer, and it tells me "error code 10 device wont start". it won't even go to the boot screen
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
you can hold down the power button and volume down button together. eventually it will give you the option to reset. use volume down to select it then hit power again.
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
Looks like the software got corrupted , you need to do a hard reset the phone . To perform a hard reset 1. Pull out the stylus.2. With the device turned on, press and hold the VOLUME DOWN andENTER buttons, then press the RESET button with the stylus tip.3. Release the RESET button, but continue pressing the VOLUME DOWN and ENTER buttons until you see this message on the screen: 4. Release the VOLUME DOWN and ENTER buttons, then press theVOLUME UP button to perform the hard reset, or press any otherbutton to cancel the reset.
A hard reset would be in order...just remember to remove your microSD memory card to avoid it possibly being erased. Here is what you do. Power down the phone. Press the volume down and the power button at the same time and hold them until you see the HTC logo. A white screen will come up with menu options. Press volume down until you get to factory reset. Press the power button the the phone will restore to factory settings.
Hi you will have to try doing a hard reset or factory reset to fix this issue . PLease follow the below procedure . This will reinstall all the drivers and reload the OS
Doing a hard reset will make you loose your data on the phone .
Performing a factory reset using phone buttons
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using buttons on the phone.
With your phone powered off, press and hold the VOLUME UP and VOLUME DOWN buttons.
While holding the volume buttons, press the POWER button briefly and then release it.
When you see a warning message on the screen, release the VOLUME UP and VOLUME DOWN buttons.
Press the VOLUME UP button to perform the reset, or press any other button to cancel the reset.
go to settings, then press the menu button so you go to all settings, tap sounds and notifications, then along the bottom tap notifications, then from the event drop down list select "phone: incoming call" and then on the ring type drop down list select "vibrate and ring"
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
..hm I suppose you installed some new sofware or tried to tune up something in the registry entries, isnt it? First try to unistall the latest software and if it does not help then you have to make a hard reset:
Click Start > Expert > Clear Storage. Follow the on-screen instructions to reset the phone.
or:
Power off your device Press and hold both softkeys nearest the screen Press the power button (you should see a black screen confirming this reset) Release the two soft keys Press the Green Phone button Wait untill the clean boot is finished...
I just had this happen to me yesterday. I fought with my phone for about 3 hours removing the battery and trying to restart it. It would take about 5 minutes for it to finally boot and once it did the touch screen would not work. So I did a hard boot and within 5 minutes my phone was back to normal. I lost all my contacts but I just did a restore with the backup software. To do a hard boot hold down the red and green buttons on the front of the phone and push the reset button on the bottom of the phone with the stylus. The reset button is on the right side of the power/usb plug. As I said my phone was back to normal in just a few minutes.
