Kodak EasyShare C360 Digital Camera Logo
Posted on May 11, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cannot format my brand new memory card in my Kodak Easyshare.
I have a Kodak EasyshareC913. Prompt reads "memory card needs formatting". When I click ok and continue it starts to format and then stops.The "card needs formatting" prompt keeps reappearing. I cannot get to the menu with the card in the camera and when I take the card out, go to the menu to get the formatting prompt, put the new card in..it starts the same cycle.(needs formatting, starts to format and stops before completion.
  • 5 more comments
  • deborah1949 May 11, 2009
    I tried that and I was prompted to move the switch back to the original position to unlock the protection.
    The card size is 4GB. SDHC is on the package. I have a card reader. Nothing happens when I plug it into the computer.
    I'm going to take the card and the camera back to the store (I just purchased them together last week) and start from scratch, new camera and new card. We'll see what happens.
  • Bob B May 11, 2010
    Have you tried putting the card into a card reader on a computer to make sure that you have a good card? Cards can go bad, also if you have the wrong speed of card some cameras can't use them. The Kodak you have is HD and requires a high speed sd card. The old plain cheapo sd cards have a 2MB/Sec transfer rate while the new high speed ones have a 15MB/Sec transfer rate. Make sure the camera is off when you insert the card and that it says 'high speed' or 'ultra' on the card.
  • Anonymous May 11, 2010
    what is the card size?
    Do you have the card unlocked so it can be formatted? On the edge of the card is a little sliding switch that locks (write prevents) the card try moving the switch to the other position and try again. See if that fixes it for you.
  • Jojo Johnson-clifford Jan 13, 2022
    My SD card for my kodak easy share won't format this the 2nd one I had to exchange. It's brand new. Need help
Bob B
Level 3:
President:
  • Master 272 Answers
  • Posted on May 11, 2009
 Bob B
Master
Level 3:
President:
Answers
272
Questions
0
Helped
224618
Points
1890
The I would have to say bad card. Do you have another to try?
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 1 Answer
  • Posted on Jun 04, 2009
Anonymous
Contributor
Level 1:
Welcome Back:
Answers
Questions
Helped
989
Points
Believe the 4 GB card is too large for this camera and internal camera software was not designed to format or manage so much memory.. try a fast SD under 2 GB.
2answers
I have a Kodak EasyShare C330. I have a new memory card Kodak SD Card 128MB. When I insert it in the camera, a message displays stating memory full. When I try to format the card to the camera I received...
This error message means that the card is corrupted or formatted for another digital camera. Turn off the camera. Insert a new card or format the card.
Try to format the memmory card using a card reader and the PC this should solve your problem if not you have to replace the memmory card.
2helpful
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
5helpful
2answers
Brand new memory card
I have the same problem with the same camera. I checked other sites and it seems that the C330 takes only SD cards up to a max of 1GB. It won't read SDHC cards and it won't read SD cards greater than 1GB.
Tried two different brand sd cards. c533 tries to
Try turning the camera off and then back on.Ensure that the memory card is the proper type for the camera. If the memory card is the proper type, try re- formatting the card using the Format option in the Delete sub-menu of the Playback Menu. If it will not format, it is probably corrupted. Replace the memory card
2helpful
We insert a memory chip into our Kodak EasyShare C190 camera. The read-out informs us that the memory card requires formatting. We click on "OK." The camera goes into a "formatting" mode, then informs us...
Your camera is only supporting SD/MMC Cards (up to 2 GB) and KODAK SDHC Cards (up to 8 GB).
The card that you currently have might be faulty. Please try another card.
You might also need to switch the camera over to saving pictures directly onto the SD card.1: Menu, Cam settings, Chose AUTO or SD card option Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
2answers
CANOT FORMAT MEMORY CARD ON DX6490
Try to open the files with a computer. Then try formatting it. For that
1. Click Start->Run
2. Type CMD in RUN
3. Then the DOS prompt will appear.then give the command for formatting......ie,
c:/>format H: /fs:fat32
*where c:/> is 'C' prompt
H: is Memory Card drive letter
FAT32 is file system
When I inset my memory card into my camera it reads memory card requires formatting. What does this mean? New memory card causes prompt to format card but camera does not complete formatting successfully....
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • 9helpful
    2answers
    Format Memory Card Error
    The problem with the c350 is that it does not accept a memory card higher than 1GB! I found that out through the Kodak website and not in the User's Guide!
    1helpful
    2answers
    Cards not working with camera
    If you used the SD/MMC memory card in another brand of camera or device, you may need to format the card in your new EasyShare digital camera. (You may have noticed a "Memory Card Needs Formatting" message when you inserted the card.) CAUTION: Formatting deletes all pictures and videos, including those that are protected. Removing a card during formatting may damage the card. To format the SD/MMC memory card or the internal memory of the camera: Transfer images to the computer before formatting the memory card. Press the camera Menu button. Highlight SETUP MENU, and then press the OK button. Highlight FORMAT, and then press the OK button. Highlight an option - MEMORY CARD (deletes everything on the card), CANCEL (exits without formatting), or INTERNAL MEMORY (deletes everything in internal memory). Press the OK button. Highlight Continue, and then press the OK button. Wait until formatting is finished before removing the card. When formatting is complete, the SETUP MENU is displayed. Press the Menu button to exit the menu.
    Top Kodak Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Kodak Camera Expert? Answer questions, earn points and help others
