SOURCE: We bought the Jacuzzi Perfecta toilet 1 year ago
The complication here is that Jacuzzi does not make toilets anymore than Sears makes refrigerators. In Sear's case their Kenmore refrigerators are from Whirlpool with the Kenmore name.
It is my understanding that Eljer was the manufacturer of the toilets with the Jacuzzi name typically sold at box stores. With that as a starting point, surf the web for any Eljer toilet tank replacement parts and see if you can find a similiar flusher
SOURCE: Need a flush valve / float assembly for my one
1-800-891-0896 http://www.efaucets.com/f/jacuzzi-ez33-959.shtml
Check this web site out I hope it will help.
SOURCE: I have a Jacuzzi Perfecta toilet (bought Aug. 21,
Have you tried shutting water off and take top of valve appart and flush it out. It may have something in valve causing water to be restricted. It will have an arrow on it to direction to get it to come off.
Take appart and clean rubber disc and you can put something over top of valve , a small cup or something to enable you to flush the tank. Have someone help you and hold the cup above the valve so that when you turn water on for a few bursts to flush out the valve it goes into tank.
The actual stream that flows through valve is restricted down to almost 1/8 " opening so it wouldn't take mush to block the flow of water.
The disc you take out you can replace it, if it seems to be damaged and not working correctly. That will affect the flow also.
Testimonial: "I took the valve apart. It is working like it is supposed to. That sure is a tiny hole for the fill water to shoot through. that is why it is so slow. It still whistles when filling. Tnx Walter Neaves"
SOURCE: replacing flush valve jacuzzi toilet
I am having the same problem. Looks like we'll need to order directly from the manufacturer.
