How to connect optical driver
SOURCE: IR receiver on unit not working?
Sounds to me like the issue is the rx in the unit. It can be fixed with very little work if you can locate the part. Let me take a look and see if I can locate the part number for you. Although I have to say that Kenwwod can keep a tight lip on their parts lists.
It seems to be a general problem on Kenwood Receivers. Pls check this out http://www.moerk.org/kenwood/ or this http://resnet.uoregon.edu/~gurney_j/kenwoodrepair/
regards sgershoj
SOURCE: Kenwood VR-209 Receiver doesnt stay on
The power transformer is bad. Part # L07-2485-05 it costs about $ 85 bucks to replace it. It is the big one.
SOURCE: Got a Kenwood vr405 surround receiver, a Sanyo
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Testimonial: "Thank you for the insight. I may have figured this out on my own eventually but this definitely got me situated much much faster. "
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Kenwood-VR-505-Receivers-manual/id/480ag214/t/2/
Page 21
I personally would recommend minimum TV involvement in sound and minimum receiver involvement in video, but that's just me.
You might want to ponder why you would need audio from a TV in the first place if it originates elsewhere like a Cable Box. The fewer hops and interconnects a given signal takes on the way from the source to your ears, the better (and cheaper, too, as optical or HDMI cable is expensive). You COULD skip the TV entirely. Many don't even HAVE audio (monitors, for example). The receiver only NEEDS a basic composite video output to the TV so you can use the TV for setup and control. You COULD run vanilla stereo audio to the TV from the Cable Box for watching Oprah.
I run all of my best DIGITAL audio directly from the sources to my VSX and the best DIGITAL video directly from the sources to the TV.
