Maytag 24 in. MDB3700 Built-in Dishwasher Logo
Posted on Oct 12, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking dishwasher My husband installed a new floor and moved it to put floor under it and now it is leaking and he cannot find where is leaking from. thanks
Anonymous
Level 3:
  • Maytag Master 43,501 Answers
  • Posted on Sep 29, 2010
Anonymous
Maytag Master
Level 3:
Answers
43501
Questions
0
Helped
10837843
Points
101584
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
du256
1helpful
Water leaking under floor when dishwasher runs
check the water to the unit it is locate under the door open the panel 2 -4 screw take flash light turn the unit on and see where the water come from ... it might be also from under your sink.
Jan 01, 2010 • Dishwashers
Flooded my kitchen
fill valve got stuck it will happen if you have hard water it is in the bottom left corner of the washer move it around with your hand
Leaking
this is a huge problem for you. when you have a leak coming from the bottom of the dishwasher the machine will have to come out. but first check the door gasket to make sure the leak is not coming from there.
Water leaking after cleaning filter
Sounds like a washer problem. Either the wrong ones or did you forge to clean the washers before reinstalling them?
We found water on the kitchen floor by and under the dishwasher
Check along the bottom inside of the door if the edge is cut up or has nicks in it from silverware being pulled across it than that is the source of the leak try putting a couple of strips of tape along that edge and run another cycle if it stops leaking or leaks less you have to replace the inside door panel and it will work fine again cost between 20 and 40 dollars depending on where you order it from
Leaks, doesnt drain properly and cloudy film on glasses
u have water under dw .and overfill switch turninng on only  drain pump all time.second from bosch water  water never leaks on floor.
UNDISSOLVED SOAP RESIDUE AND
Dispenser door sticking. Run it a few cycles by putting the tablet in the cutlery basket.
2answers
Kenmore Dishwasher installation
taking astab at this but your kit floor has been replaced and to close to counter now????, your either shimming up counter or removine the floor from under d/w
2helpful
Kenmore Elite Dishwasher 16939
I have the same model dishwasher with same problem. The gasket first came loose just after my warranty expired. The stainless steel and heat don't make for a good combination with the glue that holds the gasket in. My husband works with caulk and the like. He found a clear gel of some sort to get everything to adhere. It's had to be reapplied. I just make a habit of making sure the gasket is seated in its track and watching if dishes on top rack catch the gasket when I pull rack out.
See www.repairclinic.com, item #1065754, White silicone adhesive, specially formulated for use in the dishwasher to adhere tine tips & door gaskets. It's an accessory for this dishwasher. I don't know if Sears Parts Direct offers it. Sometimes their price is lower.
From above website it costs $14.55
Dec 12, 2007 • Dishwashers
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
