My galaxy 73v is transmitting off frequency is there a wasy to adjust it back on tofrequency
To add 10Khz to your transmit frequency:
FIXED/OFF/+10KHz SWITCH: The left position puts the radio on
one of the three fixed channels that is selected by the channel switch
(6,19, or 21). This over-rides the channel selected by the 40 channel
knob. The right position adds 10KHz to whatever frequency you are ON.
In the middle, both features are OFF.
Otherwise, a radio tech would be able to retune the frequency inside the radio.
After adding 10KHz to your frequency, use the SWR control to check the SWR of your antenna.
Here's how:
SWR CAL CONTROL: Normally this switch is set to “PO”. Then,
during transmission, the meter indicates output power. To read SWR,
rotate this knob during transmission until the needle moves to the “SET”
point on the SWR scale. Then, while still transmitting, set the R.B./SWR
switch to SWR.
Ideal SWR is 1 but you'll want to be as near one as possible. An SWR of 1.6 or greater will make ineffective use of your antenna.
If in doubt, a radio tech has the required meters and tools to adjust the SWR/Tuning of your antenna.
