Kip 3100 Toner 2/Box Logo
A
Anonymous Posted on Dec 03, 2013
Radf error kip 3100 - Kip 3100 Toner 2/Box
2answers
HOw to remove C 550 error in Toshiba Photocopier?
Hi Jawad, I hope you came right if not you can maybe ask the guys over at Thoshibatech?
Toshiba Copiers South Africa 1 Toshiba Printers For Sale
Toshiba e 233 is error code C550 how to clear
Communication error has occurred between the RADF and the scanner.
(1) Check if the harness connecting the RADF board and SLG board is disconnected or open circuited.
(2) Check if the conductor pattern on the RADF board is short circuited or open circuited.
(3) Check if the conductor pattern on the SLG board is short circuited or open circuited.
(4) Replace the RADF board.
(5) Replace the SLG board.
Estudio232 error C550
RADF I/F error: Communication error has occurred
How to remove error e712
Clean RADF (document feeder) feed rolls with wet cloth, and open RADF cover and blow air so to clean and dust or small paper.
Kip 3000 error 02
he KIP 3000 is a single footprint Multi-Function Printer which can copy, scan and ..... In case the following Error Codes for a serious failure appear in the screen;.
How to remove error code c550 in toshiba photocopier
Its error description is "Communication error has occurred between the RADF and the scanner".
Its causes is RADF board SYS board
  • RADF board
  • Check if the harness connecting the RADF board and SYS board is disconnected or open circuited.
  • Check if the conductor pattern on the RADF board is short circuited or open circuited.
  • Connector check SYS board
  • Check if the conductor pattern on the SYS board is short circuited or open circuited.
  • Connector check
For the more detail visit the link:
https://printcopy.info/?l=en&mod=erc&brand=Toshiba&model=e-Studio%203555C&code=C550
2helpful
How do you fix error code c55
Here are the steps they recommend in the users manual for a c55 error.
5.1.11 Optional communication related service call
[C55] ADF I/F error
[F11] ADF I/F error
(1) Check if the connector CN71 on the ADF/RADF board is disconnected.
(2) Check if the relay connector between the ADF/RADF board and the PFC board is disconnected.
(3) Check if the connector CN246 on the PFC board is disconnected.
(4) Check if the connector pins are disconnected and the harnesses are open circuited.
(5) Check if the conductor patterns on the ADF/RADF board and the MAIN board are short circuited
or open circuited.
(6) Replace the ADF/RADF board.
(7) Replace the MAIN board
Ce40 error on toshiba 3040c
CE40 is image related problem, u need to check which PU is giving the problem
1helpful
3answers
Kip 3000 plotter
voltage error 031-034 on the kip 3000
Top Kip Office Equipment & Supplies Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kip Office Equipment and Supply Expert? Answer questions, earn points and help others
