Question about HP Pavilion dv6000z Notebook
My lenovo Y550 is connected with lcd through HDMI cable I m pressing Fun key + f3 but still not getting display
2 Suggested Answers
SOURCE:
SOURCE: problem hdmi connection
Hello, I'm from the Netherlands and I had the exact same problem with my philips lcd...
So what I did, was upgrading the software of my videocard (nvidia.com),this resolved my problem of giving a error on my laptop and restarting.
Then I got the message on my tv: "video not supported' , this I don't know exactly how i resolved this, but i tried fn+f4 a couple times. If that doesn't work you have to do something with the nvidia control panel (right click on desktop).
So now i had picture, but no sound.
To enable sound from your laptop to your tv you have to go to control panel>sound> set the SPDIF to your standard sounddevice and tick the box with wma audio something, tick out the other boxes.
I hope this will resolve some of your problems and others who have the same problem.
greetings,
Sam
Posted on Feb 12, 2009
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
Cant connect lenovo y410 to external vga , l have tried fn plus f3
Hi
Have you install your graphic driver properly?
1. First you must check if your graphic driver to the latest update.
2. instead of using fn + f3 try using windows + P
3. check your vga cable if not broken try other vga cable or use hdmi cable.
Apr 03, 2015 | Lenovo IdeaPad Computers & Internet
Lenovo T60 install with windows7 -- now cannot connect to display
Look for a button that says "LCD/CRT"
Press this key combo:
fn+[whatever key the text above is on]
Jun 26, 2013 | Lenovo Computers & Internet
Does Lenovo 3000 Y410 support dual monitors
Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
May 18, 2012 | Lenovo 3000 Y410 (59012354) PC Notebook
I'm trying to connect my lenovo 3000 n500 to my tv with hdmi cable but it not working is there asetting i have to change
check the resolution on your laptop, make sure it is set properly. also try and press the function key that controls the display output.
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
May 17, 2012 | Lenovo Computers & Internet
How to connect dish tv to my laptop? It has inbuilt tv tuner.
Your Lenovo laptop can be hooked up your TV if you have a model that is capable of TV output. Newer models with HDMI ports can easily connect to newer TVs that have HDMI input jacks. For older laptops or TVs, you will need other adapters or cables. The most common of these is an S-video jack, which has a small round connector with several pins arranged in a circle. For S-video connections, you will need to hook up the audio from your laptop to your TV separately.
Things You'll Need
HDMI cable
USB-to-HDMI adapter
OR
S-video cable
Audio cables
HDMI Connection
Turn on your Lenovo laptop and HDMI-enabled TV.
Connect one end of your HDMI cable to the HDMI port on your laptop. Lenovo's IdeaPad series has these ports. If you have a ThinkPad or other Lenovo model, connect a USB-to-HDMI adapter to your HDMI cable, then plug the USB end of the adapter into any USB port.
Press the "FN" and "F7" keys on your keyboard. This will switch the laptop's display to the TV. You can then use your TV screen as a monitor or use the laptop's DVD drive to watch movies on your TV.
S-Video Connection
Turn off your laptop and TV. Connect your S-video cable to the laptop on one end and the TV on the other.
Plug audio cables into your audio out jacks on the laptop. If you do not have stereo audio output, you can use the headphone/speaker jack. Add a splitter adapter to split the sound into stereo instead of mono (single speaker). Plug the other ends of the audio cables into your TV.
Turn on the laptop and let it boot up. Then turn on the TV. Right-click on your desktop screen, then select "Properties."
Click the "Settings" tab, the "Advanced" button, then "ATI displays" or "Display device" or the similarly worded option, depending on your system. It is not the "On screen displays" option in any version.
Click on the option that suits your system, such as "TV" or "LCD." Click "Apply," then "Yes" to confirm, if necessary. Click "OK" to exit. Your display should be visible on the TV screen. If not, try pressing "FN" and "F7" to toggle the display to the external screen.
Sep 13, 2011 | Lenovo IdeaPad Y560 Laptop
I am trying to connect my lg 50'' plasma trying to my lenovo through vga to hdmi cable ,but am not geting display on lcd.
from a cable box you must have the box in hdmi mode turn cable box off with tv on and press menu on cable box remotly scroll down and turn on HDMI
Nov 18, 2009 | LG 50PX5D 50 in. Plasma HDTV
AcerAL1714 LCD Not Connecting With DELL Inspiron 15 Vista Laptop
There is a symbol of Two monitors on F3 Or F4 button
1. Press Fn key and hold it
2. by holding Fn key press F3 key
Your monitor will start displaying
Oct 05, 2009 | Acer AL1714 17" LCD Monitor
Swithcing from laptop screen to lcd monitor
Hi
Connect the monitor, flat panel, or projector to the laptop's 15-pin video connection on the back of the computer as shown to the right. Once connected, your laptop may automatically switch to the new external display or you may be required to press a sequence of keys in order to switch from the laptop to the external display. video.gif For example, often either Fn + F3, Fn + F5, Fn + F8, or Fn + F9 is pressed to switch between alternate displays. So if your laptop was Fn + F3, pressing and holding both Fn and F3 at the same time would switch between displays. Often, the alternate key pressed in conjunction with the Fn key will be labeled as CRT/LCD and/or have a picture of a monitor on the key or close to the key. Unfortunately, the keys pressed to switch displays is dependent on the model and manufacturer of the laptop. If none of the above key sequences work, consult your laptop documentation or consult your laptop manufacturer.
Some laptops also have the ability to have the display on both the laptop and external display and/or one or the other at a single time. Laptops with this ability can switch between these modes by continuing to press the same function keys until in the mode the user wants.
Feb 01, 2009 | HP Pavilion dv6000z Notebook
HDMI HP Labtop to Mitsubishi HDMI not working
Easy...first connect the hdmi cable between laptop and tv. Press and hold the 'fn' key on the laptop keyboard - bottom left corner. while holding the fn key, press and release the F4 key. This will toggle the laptop between its multiple display capabilities.
Press and holfn - press and release F4 until you get an image on the big screen.
Enjoy :)
Dec 22, 2008 | HP Pavilion dv7-1130us laptop
HP Pavilion dv6000z Notebook Logo
51 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
