Home Logo
A
Anonymous Posted on Dec 04, 2013
Timer will count down but won't ring - Kikkerland Home
4 Related Answers
Anonymous
  • 212 Answers
  • Posted on Jun 22, 2009
SOURCE: timer counts down but nothing happens
one of three of your micro switches that monitor your door is bad. easy to fix. remove control panel and u will see the switches that the roll cam for your door hits.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 13, 2009
SOURCE: sharp R-1460A Timer counts down very rapidily and no heat
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 16, 2010
SOURCE: Light on ,timer counting down but not turning or
See this file on door switches.
ercupa190
ernesto cuadra
  • 12223 Answers
  • Posted on May 24, 2012
SOURCE: My clothes dryer timer won't work and it won't heat up
Dear Sir:
See this possibles causes:
1) Do not work
Power house: test for blown fuse or c. breaker tripped, replace or reset
door switch: test for open or defective see the video
thermal fuse. test for open or defective see the video
wiring: see for burn or breake test for continuity see the diagram
heating element: test for burn or open see the video.
God bless you.
Does westbend still make model 40032 triple timer?
Our final tests were for durability. Some cooks grumble that their electronic timers fail after only a year. So we dropped all the timers onto a hard counter from a six-inch height and then into a bowl of water to see if any survived. Once most of the timers had adequately satisfied our initial basic performance tests of accuracy and ease of use, it became evident that the rating would break on the issues of features and durability.
Only one timer, the West Bend Clock/Double Electronic Timer Model No. 40031x, passed performance tests and had all of the functions we were looking for and then some. This model comes equipped with two timers, an easy-to-read display, long timing capability and the ability to count up after the buzzer sounds. In addition to all that, it is also a clock. The simpler West Bend Model No. 40032 won second place because it features a large, easy-reading display and stays solidly on the counter while being manipulated (other lighter-weight models slid easily) for a very good price. The Polder single timer won third place because it times up to 24 hours, counts up after the buzzer sounds and offers the bonus of an attached meat thermometer. The triple timer rated only fourth place because it costs so much for what it is, the battery is a bear to insert, and we were outraged that the battery is not included. The Big Digit rated last because it doesn't show seconds.
The remaining electronic timers, little different from each other, were rated on design. The Cooper Chef's Timer-Stopwatch was downgraded, as we didn't buy the logic of carrying the timer around our necks.
How items were judged
Eight electronic timers from six different companies were tested and judged on the basis of the following criteria. West Bend sells an additional single timer with smaller buttons; we chose the 40331x model because it was exactly the same with larger buttons.
- Price: Retail prices from New York City and Boston kitchen stores and mail-order catalogs.
- Maximum time: Two of the most important features of an electronic timer are that it time foods that cook for several hours and display seconds as well as minutes. The seconds display is crucial for professional cooks or for home cooks timing eggs or other items requiring precision. Timers that counted more than 100 minutes and displayed seconds were rated more highly than those that didn't.
- Number of timers: If you're going to buy a timer, you might as well buy one that can time more than one dish at the same time.
- Counts up after beep sounds: All of the timers count down from the programmed time to zero. In addition, timers with this feature continue counting back up after the programmed time has been reached. This feature is desirable for recipe development and testing. And if you miss the beep, you'll see how long the food has cooked past the set time.
- Interrupt: This feature allows the cook to stop the timer to interrupt cooking and start it again.
- Clock: A timer that also functions independently as a clock is not common. But if your stove doesn't have a built-in clock, it proves handy.
- Memory: If you hit start again after the bell sounds, the timer begins timing from the last programmed time. We couldn't think of many situations in which this would be necessary, so it didn't carry much weight in the rating.
Tester's comments
- West Bend Clock/Double Timer: Our favorite, reasonably priced model does everything we want: times up to 24 hours, counts down and up, times two foods at the same time, and serves as a clock.
- Polder Thermometer/Timer: High-tech design single timer counts down and up and does double duty as a meat thermometer! provocative idea, but keep in mind that you can buy the winning model and an instant-read thermometer for the same or less money.
- EK Digital: Expensive single timer boasts a sleek design but small display and is easy to knock over while setting.
- Cooper Chef's Timer: Very lightweight single timer hangs around the neck for those who want to carry the timer with them. Costs more money than you need to spend.
- West Bend Timer Model No. 40030: Solid if unexciting second-place winner is an inexpensive single timer, and times minutes and seconds, but for an extra $6, why not buy the West Bend Double?
- West Bend Triple Timer: Expensive timer counts down with three independent timers. Open the package to find that you must buy the battery. It only rated highly because, as advertised, it times three foods at once. But for $4 less you can buy two of the winning timers.
- Terraillon Micro-Timer: Small, cheesy-feeling, single timer has a small display; for just a bit more you could buy the winning West Bend.
- Time Check Big Digit: Large display timer doesn't display seconds but times up to 20 hours.
Enter service mode, GE GTWN5650FWS washing machine. won't spin or agitate...just makes clicking noise. drain pump works. timer counts down.can I check the transmission operation by putting mac
NOT SURE WHAT UR MACHINE WILL DO IN SERVICE MODE BUT DOUBT IT CHECKS TRANNY? THE LIKELY CULPRIT IN UR CASE MAY BE A DEFECTIVE DOOR SWITCH? OR WORN MOTOR COUPLER ( BETWEEN TRANNY AND MOTOR) DOUBT ITS UR TRANNY?
1helpful
Electrolux washer playing up!
Remove the top panel, there should only be 2 or 3 screws on the back of the panel, then slide the top panel back about 1/4 inch and it should lift off. Look to see if the belt has come off. Post your results back.
Dear Sir:
1) Do not work
God bless you.
May 23, 2012 • Dryers
1helpful
Switch not ticking after setting time. model Woods 59717 60 minute indoor in wall timer
Spring wound countdown timers turn on the load after dial is turned.
If your timer is not counting down, and turn knob is not rotating back to the start position, then timer is no good.
This timer counts down even if it's not connected to electricity, so the problem is not wiring.
My dryer timer counts down to 7 minutes and then continues drying
replace the sensa board and make sure the wires on the sensors are ok
How do you set the timer on a Finepix F50D, I don't have the manual with me
Press the bottom part of the ring around the menu/ok button to activate the timer. Press once for 10 second count down and twice for 2 second count down. Then press the picture button as normal and the count down will start.
3helpful
Toll saver does not work. Ring count set to 4 rings
"2 rings" or "4 rings" (the default) are not "toll saver". You need to set the ring count to “toll saver”.
On the handset
1) Press Menu
2) Scroll down to Answering Device then press menu
3) Scroll down to Settings press menu
4) Scroll down to Ring Count press menu
5) Scroll up to “toll saver” and then press menu
Ring Cont on Canon LC 8500
lift up the 2 keyboard panels and press data registration and press set. scroll down using down arrow to RX settings and press set scroll down to turn ringer on and set the ring count to 3 and set and press stop a few times.
Top Kikkerland Home Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Kikkerland Home Expert? Answer questions, earn points and help others
