When switched on, the led lights all light momentarily, then the yellow light blinks rapidly
SOURCE: pronto M51 ...the yellow light is blinks and dosen't stop
Take your drive units both out of gear and put them back in that will reset the computer and it started mine working again.
SOURCE: All the lights are blinking very fast
try pushing the chair. If the chair moves your motors are disengaged. to engage your motors look at the base of the chair there should be a lever possibly 2 push, pull or turn depending and try your chair again if you need additional help you can reach me at 404-966-3734 and i can walk you through it
SOURCE: when i turn on the chiar the led lights blink, and...
Check the freewheel lever at each wheel. If the brakes are disengaged, the chair won't let you use it for safety reasons... (ever wanted to stop at the end of a wheelchair ramp?)
SOURCE: all lights are blinking rapidly when trying to
DBowers check to make sure that your chair's motors are not in freewheel. If they are not check to make sure the charger is not still plugged in. If both of those are correct the chair might be in sleep mode. Check your owners manual to see if they tell you how to get it out of sleep mode. I think that on the Jet you turn on the chair and within 10 seconds push the joystick forward and hold it there until you hear a beep then immediately push it to the rear until you hear another beep then immediately release the joystick to the center. If you were in sleep mode the joystick should operate normally. Now I have had to try to get it out of sleep a couple of times until it returns to normal. Hope this helps
SOURCE: all lights blinking rapidly
The number of blinking lights indicate the problem. Visit this site to determine the cause:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try pushing the manual brake release levers all the way to the floor (with the power chair turned off) then back up until they pop into place then turn the power chair back on. If you continue to have a problem, contact Hoveround, they are good at trouble shooting over the phone.
