Question about Onkyo HTR500 Receiver
Connect AV receiver to a Dish receiver model VIP722 DVR
I have a yamaha RX-592 that needs to be connected to a Dish VIP722 DVR. Also a Sony DVD player. The dish box has no outlet for cable to tv, so the tech. ran form the dish receiver to the tv. He had no idea on how to connect the AV receiver and DVD player in the system. It was all working on cable and now no surroundsound or DVD.
    Master:
  • Onkyo Master
  • 699 Answers
Your DVD player should connect to your TV, not the DISH DVR. Is the Yamaha some sort of receiver or something similar? If so, it should plug into the TV as well. The DVR just provides a signal to your TV, just like the other two components. On the back of your TV there should be other connections to plug into like HDMI1, HDMI2, AUX1, etc. You select which input you want to view using your TV remote. For example, if you were watching a DVD, you turn on the DVD player. Say it was plugged into AV1 or something similar on the back of the TV. With your TV remote, select which input you are using...that way your TV receives the signal from your DVD player and nothing else.
Posted on Nov 16, 2017
SOURCE:
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Posted on Jun 02, 2008
SOURCE: Connecting a Dish 622 Receiver to the HTR500 and a Sony HDTV TV
Have a Vip-722 Dish HD receiver with a Sony receiver w/0 HDMI input and use the optical for audio for the 5.1. Using the HDMI and digital optical at the same time works fine for me.
Posted on Aug 12, 2008
mastersaintx
  • 928 Answers
SOURCE: how to connect av receiver to dvd player and hdtv
You can go to the manual at the link below and follow the directions
Links
Posted on Aug 17, 2008
  • 71 Answers
SOURCE: Hook cable box to this receiver
I have similar situation with my TXDS 565 and could not video out of my unit after hooking up the cables properly in and out of the unit for all auxilary modules... I assume that you have tried to place your vid IN from the cable box to your units vid IN and run a vid OUT cable or S cable to your TV. If this doesn't work for you as it did not for me, then you must run your cable direct to the TV vid IN and run your audio out from the TV audio Out back to your reciever as audio IN in the Video I or II ports on the reciever unit. This will give you audio control through the rec. unit.
I suspect that my is damaged and will not function properly; yours may be too,
My unit is about 10 years old and repair is too expensive so I will run it this way until something else fails and I will replace it... probably not Onkyo.,'
Let me know if I clearify any of this.
Posted on Jan 02, 2009
  • 14 Answers
SOURCE: Dish Code for TX-SR806
Dish Network
System
00775, 01505,
01775
Posted on Mar 03, 2009
I have a new Yamaha AV receiver rx-v381,trying to connect an old CD DVD player, Sony dvp-nc665p. I have audio, no video. No HDMI on CD DVD player. What am I doing wrong? Help!
On my Yamaha AV receiver, DVD video (usually a yellow connector) passes through to a video output which then connects to the video input of the TV.
Feb 11, 2017 | Sony Audio Players & Recorders
I have a DISH Network ViP722 DTV Receiver / 350-Hours Video.... Whenever I have my brightness setting below 40 on my LG TV, my Dish DVR will no longer respond to its Dish issued remote control. If I turn...
Hello! Daniel Busa with Dish Network. That would be a case of remote interference. You'll need a model 6.3 or 6.4 remote. You can set it to a uhf frequency instead of an ir that will correct the issue.
Aug 26, 2010 | DISH Network ViP722 DTV Receiver /...
Need an drawing showing hou to connect yamaha rx-
Hell Fixya customer,
Here are two links for the Yamaha receiver, and the Sony user manuals.
Please look through them concerning your specific hookup. If you still have questions or need help, please let me know.
http://www2.yamaha.co.jp/manual/pdf/av/english/re/RX-V430e.pdf
http://www.sony.com.au/support/product/kdl-52z5500
Thank you for using Fixya
May 01, 2010 | Yamaha RX-V463 Receiver
Connection Problem with HDTV, Receiver, DVR, and DVD
check the setup menu to direct your inputs from the hdmis. its all in the setup menu. good luck
Feb 10, 2010 | Yamaha RX-V463 Receiver
Problem connecting DVD/VCR to DISH
Dish dvr can only output so you have to connect your dish dvr to your dvd/vcr and then connect your dvd/vcr to your tv and im sure it should work
Dec 19, 2009 | Televison & Video
Connecting a PS2
the rxv463 will not upconvert any video signals. its what they call a pass thru video switch. chances are you are using a red, white. yellow (composite) connection. you will then need to pass this yellow thru the receiver to the yellow output of the receiver and into the yellow input on the tv. the same rule would apply to the component inputs and outputs as well as the hdmis
Dec 07, 2009 | Yamaha RX-V463 Receiver
Program sony remote to operate dish vip722
The Sony RM-YD029 Remote control will work with the Dish Network VIP722 DVR HD Satellite Receiver, but the Dish Network VIP722's Primary remote address must be set to 1.
The procedure below will allow Sony RM-YD029 remote control to operate Dish VIP722.
Using the Dish Network Remote Control -
1. Press menu 2 times to get to system info page
2. In the system info page the primary remote address is in a white box (bubble) followed by a Green TV (1)symbol that says IR and indicates you the channel your remote control one is configured. The Sony RM-YD029 will work when this primary remote address number (in the white box) is set to 1.
If the Primary Remote Address of your VIP722 Remote control 1 is not set to channel 1, here is how to change it:
1. While displaying the system info page, press and hold the SAT button on your dish network remote until all other modes are flashing, about 3 seconds.
2. then press the '1' button on the numeric pad of your dish remote
3. then press the '#' button on the numeric pad of the dish remote
4. then press the 'record' button (red dot button - stores setting)
5. At this point you should see a number 1 in front of the primary remote address on the dish system info page
Ensure you enter the corresponding IR code into your Sony remote control per the instructions in the manual or Sony's web site. My 722 works with Sony IR code - 01775.
Sep 08, 2009 | Sony BRAVIA XBR 52 in. LCD Flat-Panel HDTV
I need to connect my Dish Network 625 DVR to a JVC RX-709VTN surround sound receiver, along with my DVD and VCR. Nobody can help me at Dish Network. Seems they aren't trained to help outside of the DVR. I...
Providing you have enough input ports on the surround run you a red and white audio RCA jack from the receiver out port for TV1 and connect to the same colored ports on the satellite in ports on the surround. If you do not have enough ports then you may have to use the in ports on the DVD etc to run the TV through to utilize the surround system. Thanks for using Fix Ya.
Apr 07, 2009 | DISH Network ViP622 DVR DTV Receiver /...
I can't seem to hook up my DVR and VCR.
Hi..
Go to the site:
http://www.yamaha.com/yec/home.html?VNM=LIVE
Look up your model number.
You might need to register for a free password thing
Dec 18, 2008 | Yamaha RX-V461 AV Receiver
Onkyo HTR500 Receiver Logo
655 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
