Hi Glenn, thank you for allowing me to assist you!
Based on the symptoms you are describing, you may either have a communication error from the EOC (electronic oven control) or faulty door lock assembly. Let's try resetting your range by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, at this point I would highly recommend reaching out to a service technician who would be better able to assist you in the diagnosis and repair of your range. You can often locate an experienced technician in your area by going to the manufacturer website.
To better learn how to alternate between the oven's cycles, check out the manual for the appliance:
Frigidaire professional series oven manual
SOURCE: Oven door locked and fan going frigidaire professional range
Did you solve your problem? I just got stuck in the same situation! How did you stop it?
SOURCE: frigidaire professional series electric oven door won't open
MY OVEN DOOR WONT UNLOCK ON MY FRIGIDAIRE PROFESSIONAL SERIES STOVE 31606390
