Sony Ericsson W850i Cellular Phone Logo
Posted on Dec 03, 2013
Hard reset for locked kyocera brio
Want to do a hard reset on kyocera brio that I am locked out of
How can i factory reset my kyocera kona phone without the lock code? I can not remember my code lock numbers.
Yes. You can do a hard reboot but holing down the volume down while holding the power button down (from the off state) to reset the phone to factory condition. You can find a YouTube video on this.
How to unlock kyocera flip phone when I forgot code
Hi Tammy Townsend,
If you forget the screen lock password the hard/factory reset should help. But it will wipe down all data. How to hard reset KYOCERA phone HardReset info
If you need unlock code you can try https://www.mobileunlocked.com/kyocera
1helpful
What is the unlocking code for a Kyocera Hydro Life..model #6035?
Resetting the phone If the phone does not respond to taps or key presses with the flip either
open or closed, you may need to perform a reset.
There are two types of resets-soft resets and hard resets. In a soft reset,
all records and entries are saved. In a hard reset, all records and entries
are erased. If you must do a hard reset, you can restore any data that you
previously synchronized using a HotSync operation.
To perform a soft reset
May be either on or off
Open
1. Turn the Kyocera smartphone over. Open
the battery door on the back of the phone.
2. Press the reset button with the stylus.
3. Replace the battery door. Turn the phone
back over and verify that it has restarted.
HOW TO UNBLOCK TEXT MESSAGING OF A CONTACT
One way I can think of is to delete the contact, reset your phone, and then add the contact back in. I know it's a lot of work but if it helps it would be worth the bother. Hope this helps!
I forgot my unlock passcode for my kyocera how can i reset it
How do I do a hard reset when I am locked out of my phone to get passed the locked code??
How to change sim card in kyocera brio
Kyocera Brio does not have a SIM card.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
