Question about Jabra BT500V Wireless Headset
Unit will not charge. Red light just flashes
I have a Jabra BT500v. It's about Year and a half old. I had placed it in my desk drawer last year and took it out last night to charge it up. The red light just flashes after 24 hours on the wire. No charge at all. Any suggestions? Thank you Doc Davis
  • vdavis312007 May 10, 2009
    Thank you. If I can figure out how to open this little devil, I'll give it a try.
    Doc Davis
I had a similar problem with two new units.
Pressing the pairingbutton and de on/off button at the same time, while the unit was on the charger, solved the problem for one of the two.
The other still wouldn't charge.
On this one I had to do the same, but for a longer period (2 minutes at least). This solved the problem on this one too.
Posted on Jul 04, 2009
    President:
  • 272 Answers
Unfortunately the little lithium cells that they put in headsets have to have some charge left in them to communicate with the charging device if they go completely flat they will not take a charge. I've heard of people jump starting them with a 1.5 volt AA cell and two wires, but you have to be able to get to the battery first. If you can connect the plus to the plus and the neg to the neg for at least 2 minutes then try with the charger again. Otherwise just replace the battery. I just replace the batteries but I see alot of people on these forums praising the jump start method so I threw it in. Good Luck!
Posted on May 10, 2009
  • Bob B May 11, 2009
    If my solution helped you please rate me!
SOURCE:
H08882ROTX sei lattice
The drawer was very hard to place in the slider runners, took 20 mins to get it in without it locking and getting stuck. Please note the small grayish tabs in side both slider runners, very hard to press theses tabs and see them but these tabs do release the drawer from being locked when you only have it half way in the slot it goes in.
Mar 08, 2013 | Southern Enterprises Lattice 48 in....
Tip
Make your Lithium Laptop Battery last longer.
Hello folks,
Although I usually offer advice on backing up files or recovering them, I have been asked a lot lately how my 3 year old laptop still runs 1:45mins on a standard battery when many peoples 1-2 year old laptops can barely last an hour.
Simply put, most people do one of two things wrong. Both are common misconceptions and easy to remedy. First I've heard countless people tell me they pop the battery out of their laptop and toss it in the desk drawer until needed, often months. Second I have been told by more people than I can count that they leave their laptop plugged in 24/7 for most of the year.
Bottom line, although popping it out and leaving it in the drawer is less harmful to it's lifespan, both ideas are wrong.
The shelf life of most unused lithium batteries is shorter when unused than ones being used properly. The lifespan of a battery that is constantly being trickle charged is even shorter.
Most batteries in modern laptops are 4-6 cells, designed to give about 2 hours of charge and should last 3-5 years with charge life starting to degrade in the third year.
A "stored battery" has only 3 years of shelf life due to extended times sitting discharged and one that is trickle charged 24/7 may burn out in as little as a year.
Many laptop manufacturers have taken measures to improve this but ultimately the best thing for your battery is to use it. If you currently run you laptop plugged in 24/7, unplug it every night after you shut it off, then when you start it in the morning, let it run an hour before plugging it back in. This will give the battery both down time and exercise.
If your battery is in a drawer somewhere for safe keeping, put it back in the laptop, run it down then charge it over night and run it down then recharge it one more time. Store it back in the drawer charged and repeat the cycle at least once a month.
These tips will help drastically improve you batteries performance over time. My 3 year old laptop only ever got 2 hours of battery life and still gets 1:45 with no power saving measures, give it a try.
Crankstart
on Mar 20, 2010 | Computers & Internet
Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Jan 04, 2013 | Razor E300 Scooter
How to pair jabra bt500v to a blackberry curve
Paring the JABRA head set to Mobile phone
1. Turn headset off. Press and hold until solid light comes on.
2. Activate Bluetooth on your phone.
3. Search for Bluetooth devices and select Jabra BT500V.
4. Press ‘OK’ on the phone ,If the phone asks for a PIN then confirm with PIN code 0000 (4 zeros)
Thank you
Sep 03, 2010 | Jabra BT500V Wireless Headset
I want to pair my Jabra BT500V with my PC, is this possible? If so, how do I set it up please?
Go to this site, and it will walk you through each step to connect your particular Jabra headset with your cellphone. Choose the headset, and then at the next page, choose your phone. Moving your mouse over each step will change the picture to what you should be seeing on your phone at each step.
http://jabra.pairx.co.uk/ Pls come back and let us know if this solved your problem.
password is 0000
Dec 01, 2009 | Jabra BT500V Wireless Headset
Jabra red light of death
seeing the red light tells you that the jabra isn't fried or shorted and that there is life but there is a problem, the red light isn't blue when it should be. so have you read the directions your ear piece came with when you first bought it?... hold the on button until you see the blue light stays on.(blue light will flash fast then slow then come to a complete stop and stay on) once blue light stays on that should mean you can now find the ear piece on your cell phone to link up. if problem still isn't fixed then you might as well buy a new one.
Aug 04, 2009 | Jabra BT350 Bluetooth Headset Headset
How to set the Jaba BT500 headset in pairing mode?
Jabra has an online tutorial on pairing.
It can be found here:
Choose your BT500V from the list, then choose your phone / pda model from the next menus.
Jun 20, 2008 | Jabra BT500V Wireless Headset
Logitech optical mouse won't turn on with new batterys
When you say turn on, I assume you mean the mouse itself shows no indication of power. An easy way to check this is to turn the mouse upside-down and look at the red led light that illuminates the desk surface for the optical camera (This is most typically red, on particular models it can be other colors). If it's red and lit, then your mouse is receiving power. If that's the case, the problem could be that your mouse is simply not synchronizing with your system, or that it is not properly installed.
If the red light is not turning on, then the mouse is in fact defective. There is little to repair physically with optical mice, or mice in general. If you've ensured that the mouse has new batteries (not just old ones from out of the desk drawer that were new last year) and it is completely lifeless, I would say it's defective and should be replaced.
Hope that helps.
May 01, 2008 | Computers & Internet
Help
I have a brand new one with the same problem I contacted Jabra Support in AU on 1800 636 086 They advise that it is dead batery if yeaft for a very long time with out charge the batery will die and will not charge.
If its under waranty they will advise to send it back to them and repalces it with a new 2008 model.
Another isssue is look at the date, on the side of the box. My brand new one said 20/07 indicating it had been on the shelf 1 year before it was shipped.
Hope this helps
Jan 23, 2008 | Jabra BT500V Wireless Headset
Jabra BT500V Wireless Headset Logo
1,124 people viewed this question
Top Jabra Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
