Since the carpeting and padding are saturated I'd like to take out the carpeting and just polish the concrete floor that is underneath the carpet. Is this feasible?
Of course, It's possible to polish the concrete floor underneath.While planning for Concrete polishing, First you have to evaluate the material surface, then use the correct chemicals. Concrete polishing can remove scratches, stains and marks and transforming concrete to a beautiful polished shiny surface. For further enquiry, Welcome to Artech Stone and Concrete Polishing Sydney
Yes.
SOURCE: 2002 Toyota RAV4 passenger side floor Water
Hi, we also have a 2002 Toyota Rav4 and developed a leak in the front driver's side of the car. After much research, we discovered that the drain wells from our sun/moon roof were clogged. If you have one of these, I suggest that you open the sun roof and look carefully. You will notice some tiny little holes in front and in the rear of the sun/moon roof tracks. Over time, these become clogged with dust and debris. You need to find a long, sturdy piece of thin wire and run it down the holes. To test if you have properly unclogged these, take a small amount of water and pour it down the holes. You should see water coming out of the drain wells under the car around the rear of the front tires. Hope this helps.
SOURCE: water leak passenger side in dodge caravan 2005 carpet soaked
look at the firewall on the engine side and you will see a small stub hose coming out on passenger side about even with the bottom of the heater box inside. that hose drains condensation from the ac...clear it out and you will have a dry floor. (unless heater core is leaking but you didn't mention any overheat or coolant loss so likely that's not a problem)
