After getting constant paper jams in this stupid printer, I took a look and tried to fix it myself. I noticed that there is a cloth like thing wrapped around a cylinder, which is the area that the paper keeps getting jammed in. It looks as if the cloth was pulled out of the proper place, and I do not know what it is or how to fix it.
SOURCE: Lanier 7328
hi im jules_09,have you tried cleaning all the ruber roller?try cleaning all ruber roller then lubricate al bushing and gears.if there is still a problem check all paper sensor it can be cleaned with alcohol.just soak the paper sensor with alcohol then let dry after a few minute then install it back again in the copier.dont soak the paper sensor in alcohol while it is in the machine.turn of the copier first
SOURCE: Full Waste Toner Bottle in Lanier LD040
Hello sir; I believed you talking about LD045, am I right? In this model it doesn't have waste toner bottle, the only place you can clean is imaging transfer unit, after you cleanup the message will be disappear.
SOURCE: I have a Lanier LD 232c. Every print job we try to
Make sure that all the paper trays have the correct size and direction (portrait or landscape) in both the copier and print driver.
