Zanussi 23 in. ZDT6252 Built-in Dishwasher Logo
A
Anonymous Posted on Dec 03, 2013
Machine keeps clicking on and off when i press on button and temp button
Ive just moved into the house so no instructions
Heater and air condioning switch keeps making clicking noise
The noise is one of the actuators that moves the air flow doors into different positions. Common problem. When the noise happens, move the temp. control from cold to warm. If the noise goes away, it is the temp. actuator. Or, press the recirculation button to go from fresh air to recirc. If the noise goes away, it is the recirc. actuator. Or, change the mode from vent to heat. Could be the mode actuator. Usually the temp actuator acts up.
I am looking for a instruction manual for a TOYOTA E&R CLASSIC LC-21 SEWING MACHINE.Ive moved house twice and the instructions have got lost in the removals somewhere along the line as the needle keeps...
try manualsonline.com/ also could be old thread, needle not threaded correctly, tension incorrect. incorrect needle for the material. Good luck
We bought a house with Fujitsu Air-conditioners we have no instruction manual on how to use the remote. Im trying to set it to go off after an hour or so. Model No.INDOOR UNIT is, AST12RSJCW Serial No is...
Switch on by pressing ON/OFF. Press mode button to cool position. for cool and keep required temp by clicking
Same procedure for Heat. For heat keep +29 and for cool 25 to 22 degree. Press fan for High, Med,Low. If you keep mode in Auto cool and the fan speed will be low and you can't change fan speed.
Please visit Fujitsu website for further details. Hope my msg is helpful?
11helpful
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
36helpful
4answers
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
5helpful
2answers
No instruction manual
For Compass Adjustment search on Google or FixYa
For Temperature calibration:
1. Pull the crown to most extended position (2 notches)
2. Temp hand moves to a default position
3. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
4. When done, push crown to 0 position
(I used melting ice water to calibrate and fix to 0 deg C)
For Tide calibration:
1. Pull crown to middle position (1 notch)
2. Move hand in + or - direction by pressing temp or tide buttons (above and below crown button)
3. When done, push crown to 0 position
Hope this helps
I have just moved into a house with a C1920 tumble with no heat
If there is a reset on the back you may have to push pretty hard to reset it. If it doesn't click it may be faulty.
eric
Jun 29, 2009 • Dryers
Moved into new house need set of instructions
Try this. I'm not sure if it applies to your model.
The reset sequence used is:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
Hey guys
If you don't want to pay for the (expensive) repair, then stripping it down and checking that the lens motor, cogs and housing and moving correctly. It's not for the faint-hearted, but it's not really complicated… the Instructable for the FZ5 covers it http://www.instructables.com/id/Repair-Stuck-Lens-on-Panasonic-FZ5/
4helpful
2answers
Need a user manual for lg washer dryer wd 12331 ad
Click on washing machines, (below FIXYA) on this site, find your model, type in your model number & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Top Zanussi Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Renee Knafel-Bullock
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
