Hi all!! I recently synced my iPhone 4 with my computer for the first time and accidentally deleted my all data include contact, photos, SMS etc. on the phone that i would very much like to get back. Is there some sort of software out there, paid or free, that will let me recover these files without jail breaking my phone?
If you have the backup in iPhone or iTunes, there are three ways for you to restore iPhone contacts, photos,notes and so on data
one is recover them from iPhone by scanning the data directly
one is recover them from iTunes by clicking iTunes > Preferences > Devices
one is recover them with iPhone data recovery that is found easily on net.
You can follow the guides below to recover data from iPhone.
Guide 1: Directly Recover Data from iPhone 4, iPad 1, iTouch 4
Step 1 Connect your iPhone to the Computer
Step 2 Download a plug-in for your device before scanning it
Step 3 Enter the DFU Mode and Scan your iPhone
Step 4 Check and Restore your Lost Data
Guide 2: Recover Previous Data from iTunes Backup from All iOS Devices
Step 1 Choose your Device and Select the Recovery Mode
Step 2 Scan the Backup File of your Device
Step 3 Preview and Recover Lost Data
You can try this to recover deleted data from iPhone:http://goo.gl/2iBEKy
Hi, if you're looking for a really effective tool to recover data from iPhone, I strongly recommend you to use Joyoshare iPhone Data Recovery, which is 100% dependable and powerful to recover lost contacts, photos, messages and many more in a safe and fast way. For more info, please visit: Joyoshare iPhone Data Recovery for Mac
Recovering your files for some mistaken deletion is now easy to come back because there are a lot of tools that are available in the market for you to make your iPhone have a safer recovery just try this data recovery tool Whatsapp Recovery for you to have a safer data and a safer life to live ;)
Please also read this guide to know how to delete photos from iPhone.
http://www.leawo.org/tutorial/how-to-delete-iphone-photos-synced-from-computer.html
Check if you have iTunes or iCloud backup of your iPhone first, if you have either of them, try to recover deleted data on iPhone with previous backup with iPhone Backup Extractor.
iTunes and iCloud will automatically back up your iPhone even if have not done it manually:
iCloud automatically backs up the most important data on your iPhone on a daily basis as long as your device is:
Connected to the Internet over Wi-Fi
Connected to a power source
Screen locked
iTunes can create backups of your iPhone automatically when you sync with iTunes (disabled if you have iCloud backup turned on).
Still haven't found your iPhone backup? Try this iCloud Data Recovery
You will need a third-party software to help you recover lost contacts, messages, photos, notes, call history from your iPhone, more detailed information, you can view here, How to Recover Deleted Data from iPhone
Generally speaking, if you accidentally lose all your data when you sync with iTunes, there may be a backup file in iTunes. You can check that if you have backed up data successfully.
Launch the latest version of iTunes, and click Edit > Preferences > Devices
You can see whether you have backed up data or not. And select the previous one, click "Reset Sync History" and then it works.
However, if you can not back up from iTunes, you'd better try some other data recovery software to overcome the problem. Like iPhone Data Recovery, which can recover lost data from iPhone directly.
Remember not to use iPhone any more, maybe the new data will overwrite the lost data.
Google to find some tutorial to get more information.
It might be use of you.
How to recover deleted data from iPhone
It becomes very easy to recover data from iPhone. Below are the steps about how to do it. Recovering data from an iTunes backup is typically much quicker than from a device, because the data's already on your Mac.
You can recover your data by using iTunes Backup
1.FoneLab can open up the contents of any iTunes device backups on your Mac, and give you the same level of access that you'd get with an attached device.
2.The steps for retrieving your data from a backup file are exactly the same, except that you select from a list of backups on your Mac's hard drive rather than connect the device to your USB port.
3.You can then either selectively recover individual files or output all the contents of the missing device to a folder.
4.By default, Mac FoneLab will automatically open your output folder once it's finished recovering your files. From there, you can use the data as if it had never been lost at all.
Thanks
If you want to recover data on iPhone, you must to use a iPhone Data Recovery, the use guide about how to recover lost data from iPhone is not bad.
Next,let's shows you the way to recover iPhone/iPad data:
One. Recover Lost or Deleted data from iPhone directly
1. Connect the iPhone to computer
2. Scan your iPhone device with iPhone recovery
3. Preview and restore iPhone data
If you have iTunes backups, just recover the deleted data on iPhone from the previous backups.
1. Connect the iPhone to the computer with a USB cable.
2. Open iTunes.
3. If you have a new or erased iPhone, iTunes will prompt you to restore from backup.
4. Otherwise, Control-click on your iPhone under devices in the left menu.
5. Select Restore From Backup...
6. Choose the backup you wish to sync and click the Restore button.
Tips:You better backup iPhone data to computer, avoid losing data and recover deleted data from iPhone.
If your iPhone data are indeed lost or deleted. I would suggest you try using iTunes in order to restore your iPhone data from the last time you last synce your iPhone with your iTunes. Here are two easy methods to recover data from iPhone:
One. Recover data from iPhone yourself via iTune:
1. Connect your phone with iTune on computer
2. Right-click or control-click on the iPhone icon under iDevice on iTunes
3. Select "Restore from Backup" from the given options
4. After it finishes, your data are back to your iPhone
Two. Recover data from iPhone by using third party iPhone data recovery software
If you have no backup for your data, you can download iPhone data recovery software in order to overcome the problem and restore iPhone data loss. Still you have not recovered lost data from iPhone, some on-line applications also available which can be helpful in restoring precious data details, probably will be able to find the solution to some extent.
And I think if you want to know more info about this you can have a look at this article: How to Recover Lost Data from Your iPhone
Many people are starting to realize how convenient it is to have scheduled notes on their phone. This can be helpful for them in terms of prioritizing their daily activities. But there are scenarios when you accidentally delete your important notes. I know it's really frustrating to delete iPhone notes accidentally or intentionally. So, can we restore notes on iPhone?
Don't worry, as there will be software to help you out. Coolmuster Data Recovery for iPhone iPad iPod software is able to get your deleted notes back. This will be very beneficial to those people who have lost notes on iPhone.
Since it is the first time that you synced the iPhone 4 with your computer, so there is no backup of your iPhone data on your computer. The only way is to restore lost contacts, photos, SMS and other data directly from the iPhone 4 device. Read more here: http://www.datarecoveryiphone.net/ Best wishes!
EaseUS iPhone program restore contact ,SMS, call log and most photos for you. Try it for iPhone data recovery
Recover deleted or lost SMS messages with iPhone SMS Recovery tool!
For iPhone 3G/4 users, you can directly recover your lost SMS message back even without any iTunes backup with the help of this world's first iPhone SMS Recovery tool! Just follow the steps !
