Re: Message tells me to plug cable into local area...
Try resetting (turning off and turning on after 3 min) your modem or router or hub (whichever you're using). Then right click the little icon in the task bar that represents your network connection and select 'Repair'
"local area connection" is the wired connection, which in your case is "unplugged" If you go to control panel and look in connections, you will see that you are connected with the wireless, if you right click on the wireless there is a checkbox to display the status on your toolbar along side of the "Local Area Connection"
Hope that clears it up a little
WPC54g is a wireless adapter. The message that you are getting is the message for the Local area connection. This message has nothing to do with the WPC54G. This message is for the wired connection and not for the wireless connection.
It sounds like your pc has 2 network cards inside of it. If you can get on the internet from that particular pc then you don't need to worry about the second connection being unplugged.
To get rid of the message... "Local Area Connection 2 is unplugged." You would have to plug an ethernet cable into the second network card and then plug it into your router or switch. But... this is not something you want to do unless you have a clear understanding of why you're doing it.
XP tags "Local Area Connection #" with your Network Adapter. If you have a built-in LAN, it will take Local Area Conn 1" and when you disabled it and plugged in a new network adapter, it will be named Local Area Conn 2 and so on in that pattern. Your Local Area Connection will only be back when you plug the original Network adapter that XP tagged as Local Area Connection. It is not "variable" where you can choose how to name it.
That message always comes up if you have the driver loaded for the ethernet port but no cable connected to it. If you are not actually using the port, don't worry about it. Everything is fine.
OK, in order to solve this problem, I will need more information:
1) What is your operating system (i.e. Windows XP? Windows Vista?)
2) Is this a laptop or a desktop computer?
3) If it is a laptop, is there a switch on the case that turns on and off the wireless ability? Check your user manual - it might be as simple as turning on the wireless switch.
4) If it is a desktop, what kind of wireless adapter did you install?
I'll be able to help more when I get this information. In the meantime, here are a few things you can do:
First of all, you need to delete all of the duplicate connections from Network Connections. They won't really hurt, but they're not helping either. To delete them, just right-click on them one at a time and choose "delete."
Next, you need to understand what the message "a network cable is unplugged" refers to: this has nothing to do with wireless. If there is no actual hard-wire cable connected to your computer, the port (that's the opening that you plug a network cable into) will tell Windows that it is empty. This results in the message "a network cable is unplugged." You can ignore it, or - if you plan to use this computer with a wireless connection only - you can right-click on the connection in Network Connections and choose "disable." This stops the message from appearing, and can be reversed (enable) at any time.
If it says that your local area connection is unplugged then you cant have a cable plugged into the ethernet socket on your pc into a router or there is a break in the cable.
